Page 6 of 101 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 1003
Thread: Hodge's new 4.2
  1. #51
    Thanks gents. Will do that this weekend then.
    Give me a call dude. I should be around most of the weekend and ill give you a plate. Do you need a spare maf? 😆
    Hodge (30th July 2015)
  3. #52
    177 Post(s)
    Will do if i get a chance mate. Car is off from shop to shop tomorrow, getting various things done, might not see it for a week. As soon as i get it back might see you about that blank.
    And what are these various thing getting done? Bar, snorkel, exhaust, lift, tyres, lockers, UHF... Shall I go on?
  5. #54
    177 Post(s)
    She's getting cleaned up and respryed under, windows tinted, snorkel and exhaust fitted... Rwc and then put through the vic roads pits for rego...
  6. The Following User Says Thank You to Hodge For This Useful Post:
    mudski (31st July 2015)
  7. #55
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Was going to respray my chassis one day but never got around to it. Probably I'm better off fixing some of the surface rust on some scratches on the body first I guess
    Lucus30's 1999 GU ST TB45E
  8. #56
    177 Post(s)
    Mine is just surface corrosion everywhere so not bad but just want to get it cleaned and repainted for a neater look and to stop it getting worse.
    I take it the new Pootrol has the standard suspension? If so I wanna look at something before you change it...
    Hodge (31st July 2015)
  11. #58
    177 Post(s)
    It does mate. Stock and will stay that way for a few weeks.
  12. The Following User Says Thank You to Hodge For This Useful Post:
  13. #59
    Thanks. I want to take some measurements of the rear brake bias before you get anything done if you don't mind mate.
  14. The Following User Says Thank You to mudski For This Useful Post:
    Hodge (1st August 2015)
  15. #60
    177 Post(s)
    Sounds good buddy. I'll have the car this arvo and most of tomorrow so i can swing by and you can measure away ...
  16. The Following User Says Thank You to Hodge For This Useful Post:
    mudski (1st August 2015)
