Page 4 of 24 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 235
Thread: Forced Offroad. Gq v8 daul cab.
  1. #31
    Expert Forced Offroad's Avatar
    Apr 2011
    Logan/Daisy Hill
    Quote Originally Posted by Bigrig View Post
    Funny thing is it is true!!! If I'm going to someones house, I always plonk a few 'travellers' in the fridge!!!
    to thumbs up there...... best thing about the 12v fridge.
    FORCED OFFROAD
    Built by NISSAN Powered by HOLDEN Perfected by ME "hulksta"
    http://www.youtube.com/watch?v=3GX2M...layer_embedded
    http://www.nissanpatrol.com.au/forum...Gq-v8-daul-cab.
  2. #32
    Apr 2011
    Logan/Daisy Hill
    Though I would chuck this in, even though its no use anymore....But worked treat...Made things easy to get at......
    You can see it closed on the you tube clip...
    FORCED OFFROAD
  3. #33
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by Forced Offroad View Post
    Excellent mod though - any details of how it was done?? Thanks chief!!
  4. #34
    x2 mate, I've been thinking of something like this...
    Would love to hear about how you made it!!!
  5. #35
    Apr 2011
    Logan/Daisy Hill
    righto then,
    1st step remove rear window....
    Actually its pretty easy to remove, I prised the bottom out with 2 chippy chisels, and went from there. once you start you will get the idea how it removes.....
    Materials.....
    Piano Hinge......... Bunnings
    Dont have a finished photo...
    But I used a product called Dibond sheeting.... plastic with aluminium finish,all different colours. 3mm thick
    #Then I cut it out in the shape of the window frame...
    #Pop riveted the hinge to the upper (under) window frame. cut to size
    #I made about a 3mm gap all around....
    #once the sheet was in the correct position. I marked hole for the hinge on the sheet....
    #I used small stainless nut and bolts for a better look as you will see the nut head from the outside...
    #bolt on sheet to hinge and see if all working well.
    #main thing you need to look at is that the hinge and sheeting will sit flush with the car.
    #from the i used Pinchweld with Side Blister, from clarks rubber.
    http://www.clarkrubber.com.au/rubber...els-seals.html
    this is the main seal. different sizes so choose the one best for you....
    This worked the best as it will pinch over the pinchweld seems around the window and give you a water a dust seal...
    Gas Strut.
    #I used aluminium right angle.
    #Screwed it to the inside of the car above window.
    #it had about a 30mm drop below the window opening
    #adjust strut to suit the window for opening and closing.
    #bolt bottom right angel to sheet. Again I used bolt as they will be seen
    The the lock.
    i used 2 on each window. This gave me a great finish and worked well as they locked behind using the pinchweld seam.
    Hope this helps....Its hard to explain.
    FORCED OFFROAD
  6. The Following 2 Users Say Thank You to Forced Offroad For This Useful Post:
    AB (6th April 2011), awyd (15th September 2015)
  7. #36
    Feb 2011
    Shed
    45 Post(s)
    Cool idea mate and an easy DIY
  8. #37
    SUCH IS LIFE Maxhead's Avatar
    ACT
    WOW...What a beast . Sorry mate I just noticed your build up. Very nice!!!
    ________________________
    ______ 2017 D-Max _______
  9. #38
    Thanks mate, It's on my list and will be coming back to this thread again soon...lol
    Always wanted a higned window each side to get stuff!
    Cheers!
  10. #39
    Jul 2010
    Waterford West Qld
    Let us know when you're catching up with Tim mate - dhuck (Dave) and I (Scotty) might pop over and say g'day also!!
    Bloody Gate Crashers.....hahahahahahah
  11. #40
    Does water get in over the pinch inside by chance???
