Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 79
Thread: NEV the nissan
  1. #51
    Yeah I know that One for my build thread one for "what did you buy"
    And one for my roofrack thread all good lol
  2. #52
    Quote Originally Posted by Oldmate1 View Post
    hi mate
    did you forget that you posted this same thing in two other places
    He's just really, really, really....... really excited for his light
  3. The Following User Says Thank You to Winnie For This Useful Post:
    Rossco (30th July 2015)
  4. #53
    Little things please little minds hahahaha
  5. #54
    My awning light just arrived, its a Kawell 18watt 60 degree beam spread.
    It will be hard wired with a dimmer and remote control as well.
    Die cast alloy body so very robust IMO cant wait to mount it,
    about 200mm long
    I thought you had to have a specific led for them to be dimmable? Most leds will work between 6 and 36 volts. Others will work in a smaller ranger but they are either on or off.
  6. #55
    We'll see in time I suppose, most other LEDs I have been able to dim even ones with a driver
  7. #56
    You do need dimmable LEDs.
    Most LEDs are dimmable though, but the drivers for them are not.
  8. #57
    changed my glow plugs happy with that, problem is now there is a problem with boost.
    Ive either crimped the hose or its leaking somewhere, easy fix ,
    again just need the weather on my side.
    I brought all new hose with spring loaded clamps with tee's so
    good time to re-do the Dawes and needle valve
  9. #58
    Time to update new glow plugs fitted and now the Patrol starts first kick very happy.
    Also fitted some switches to the centre console more to come later, little bit of running
    around in the morning then Ill cut all the other holes and fit the switch mounting blocks.
  10. #59
    176 Post(s)
    Yep it’s the driver which determines if they are dimmable or not. I just bought a bunch of 240v LED downlights for our shed dwelling. They are both dimmable 100% to 3%, 16w with 180 degree light spread & also colour changeable with stepless adjustment between 2700k (warm white) to 6000k (cool white). Dimming & colour changing is done with a remote control which can control up to 4 groups of lights containing 1 to 10 lights each. They work really well & the warm white is just like an incandescent light, not a crappy yellow like some. At $26 each they are great value & the remote .... a whopping $11.
  11. #60
    176 Post(s)
    Did I miss something? I thought you’d done a head & were talking motor replacement?
