Page 94 of 220 FirstFirst ... 9293949596 ... LastLast
Results 931 to 940 of 2192
Thread: AB's new GQ is finally here
  1. #931
    Any hose shop like Pertek will sell pneumatic hose fittings and air hose like that. That Brake Shaft was modified by Flamingfab and he welded a nut and made the end cap. I upgraded to a Gigglepin Brake shaft and gave AB my modified one. Lucky bloke.
    Again the drum has been professionally modified with an inner roller Bearing installed to replace the nylon bush that Warn use. Makes a massive difference to the friction on the drum end. I bought it a couple of years ago and again gave it to AB as I have gone a Deltatek Air Freespool.
    Haha Yes AB is a lucky bloke!! Might upgrade to a bearing end one day but not just yet, thought it might have been.
    I took my shaft into an engineering shop near work but couldn't tap it because of the hardness. It does look neat with the little cap, might have a play around see what i can come up with. . .
  2. #932
    It is a pretty basic mod mate, weld on a decent nut. Using a piece of water pipe cut the right length, weld an end plate on it. Make sure the pipe is cut the right length. ( long enough to hole the end on at the same depth that the circlip would normally, your replacing the circlip here)
    Take out the bolt on the end of ABs brake shaft and it will be very clear to see. Put a couple of clamps on the brakes first though!!!!
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Rossco (13th July 2015)
  4. #933
    Yeah sweet sounds pretty simple, that's a good way of doing it. I'll check out AB's or just steal it when he isn't looking!!
  5. The Following User Says Thank You to Rossco For This Useful Post:
    MudRunnerTD (14th July 2015)
  6. #934
    Here you go AB, everything you need to know about your rope is here nissanpatrol.com.au - Splicing-a-Dyneema-Winch-Rope
    thanks mate, that animation was an eye splice. After scouring the web this video below seems to be pretty good for splicing two joins...thoughts?
    http://youtu.be/yjhBEe_8XHg
  7. #935
    Easy as mate.
    AB (15th July 2015)
  9. #936
    Redecorated the lounge room, the misses is wrapped I'm going to splice the rope tonight.
  10. The Following 2 Users Say Thank You to AB For This Useful Post:
    Clunk (16th July 2015), Rossco (16th July 2015)
  11. #937
    Probably as wrapped as my missus was when she found me snatch strap in the washing machine, all nice and clean
  12. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    AB (16th July 2015), Bloodyaussie (16th July 2015)
  13. #938
    I bet it was reeeeal clean though!
  14. #939
    Came out like new mate
  15. #940
    rotating every 30 minutes and spacing the rope. Mrs walks in...Jesus Christ babe you're treating that rope like its a baby.
  16. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (16th July 2015)
