CC are not renouned for their service , I hope they have changed for your sake
One of those Hydraulic Crimpers. Definite Arthritis beater.....
http://www.ebay.com.au/itm/8-Ton-Hyd...item1c39c3a13e
GROOVY GUVII
Been a busy few days!! New Alternator pulley new drive belt tensioner new alternator removal tool & to top it all off a new UHF!! Now im poor again!! :-(
2006 GU IV ST MAN 3.0TD - UHF, Boost & EGT Gauges, NADS, Pro Vent 200, Snorkel, Tigged IC, 2" Lift, Dual Battery System & Still lots to come!
Got a Patrol in WA CLICK HERE - Just Go There!
New number plates for Katrol.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
Cheers Rod
My Build 2005 TD42TI
installed the 2 battery gauges with an isolator switch and mounted the water pump and switch for the tank, also spaced out the rollers on the rear drawers to stop the drawers from dropping off the runners when bashing around in the bush. Also replaced the main battery again![]()
katwoman (16th July 2015)
Cheers Rod
mudski (16th July 2015)
