Page 527 of 1057 FirstFirst ... 525526527528529 ... LastLast
Results 5,261 to 5,270 of 10564
  1. #5261
    Thomastown, Melbourne
    6 Post(s)
    Maybe. I will have to find
    someone with a pipe
    bender first.
    I just bought the bends and welded them together.
  2. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    mudnut (9th July 2015)
  3. #5262
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    Finally fitted my EGR blocking plate before... Only been sitting on the bench with my Dawes stuff for 3mths..... Now to go for a spin and see what happens boost wise, then i guess i'll be fitting Dawes and needle really soon. lol
    2003 GU SIII Auto Grenade. All the goodies.
  4. #5263
    Quote Originally Posted by Softy View Post
    You might have to, it may go into over boost
  5. #5264
    May 2011
    Radelaide
    5 Post(s)
    It's ok under hard acceleration but it's getting up there with only light acceleration... sitting on 7-8psi at 60km/h and 10psi at 80km/h.. Will give it a few days to settle and see how it is.
  6. The Following User Says Thank You to Softy For This Useful Post:
    threedogs (10th July 2015)
  7. #5265
    Advanced morton2478's Avatar
    Mar 2015
    Fitted dawes and needle valve very happy so far
  8. #5266
    .......... TPC's Avatar
    63 Post(s)
    Replaced the struts on the bonnet so I don't need a stick any more.
  9. #5267
    I know right!!! Put up with it a few months then took 10 minutes to swap out!!!
  10. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Stropp (12th July 2015), threedogs (13th July 2015)
  11. #5268
    Patrol Guru
    Jul 2014
    6 Post(s)
    More for yesterday, but went wheeling, damaged the small barn door and jerry holder that I've got on it. Fixed the door (still bent, but now opens/closes/locks), The jerry holder still works but now it looks a bit wonky. Could use a crowbar to straighten it out but it's still functional. Pretty happy that was all the carnage all things considered. Now the door makes a metal popping sound when opening/closing. Hopefully it doesn't make this sound when driving, though I have a feeling the muddies will drown it out anyway :P
  12. The Following User Says Thank You to Throbbinhood For This Useful Post:
    mudnut (13th July 2015)
  13. #5269
    Aug 2014
    Perth
    10 Post(s)
    Hey TPC where did you get those from mate? My ute's bonnet struts are broken and need replacing.
  14. #5270
    63 Post(s)
    Quote Originally Posted by gubigfish View Post
    I just got cheapies from ebay, they seem ok so far, hopefully they will last.
    http://www.ebay.com.au/itm/321133606058
