Page 93 of 220 FirstFirst ... 9192939495 ... LastLast
Results 921 to 930 of 2192
Thread: AB's new GQ is finally here
  1. #921
    Here you go AB, everything you need to know about your rope is here
    nissanpatrol.com.au - Splicing-a-Dyneema-Winch-Rope
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (12th July 2015), Woof (12th July 2015)
  3. #922
    AB even came up with the idea of mounting the light under the light bar!!!! He knows Stuff...............all.
    you liked that idea don't lie
  4. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (12th July 2015)
  5. #923
    Awesome work anyhow guys, I can't wait to see it and it's making me want mine back from the welders even more now!
  6. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    AB (12th July 2015), Rossco (12th July 2015)
  7. #924
    Awesone stuff. Will have to try out all these new goodies soon. I do like the led idea, might have to steal that one, would have been handy on that last adventure we did in the dark.
  8. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    AB (13th July 2015), Winnie (12th July 2015)
  9. #925
    Seriously changes everything in the dark mate. No Brainer. I have had a light there as long as I have had a Himount. Winner.
  10. #926
    If you don't have a lightbar handy hanging under your top rail of your bull bar then on the back of your number plate works great. That's where mine is..
    See this post from my build thread showing the light on my plate
    Quote Originally Posted by MudRunnerTD
    See on the back of the numberplate i have fitted a white LED marker light that is switched with the winch isolation switch in the dash and lights up the winch whenever power is connected to it. F*#king awesome at night for winching.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Woof (13th July 2015)
  12. #927
    Here you go AB, everything you need to know about your rope is here nissanpatrol.com.au - Splicing-a-Dyneema-Winch-Rope
    good news, was chatting to a work colleague today who has spliced rope a million times from rigging equipment and will show us in person how it's done.
  13. The Following 4 Users Say Thank You to AB For This Useful Post:
    Bloodyaussie (13th July 2015), MudRunnerTD (13th July 2015), Winnie (13th July 2015), Woof (13th July 2015)
  14. #928
    Just unwrap it and cut out the crap bit then wash it (even just through a bucket of water) then grab the eyelets and get him to sort it for you, winner!
  15. #929
    Going to do a few mods to mine whilst it's out and on the bench. Where's a good place to get air line & fittings for breathers - would a good tool shop have those? Also how did you modify the brake shaft. Did you get it drilled and tapped or weld a nut on the end? Also! What plate is on the end drum - doesn't look standard?
  16. The Following User Says Thank You to Rossco For This Useful Post:
    Winnie (14th July 2015)
  17. #930
    Any hose shop like Pertek will sell pneumatic hose fittings and air hose like that. That Brake Shaft was modified by Flamingfab and he welded a nut and made the end cap. I upgraded to a Gigglepin Brake shaft and gave AB my modified one. Lucky bloke.
    Again the drum has been professionally modified with an inner roller Bearing installed to replace the nylon bush that Warn use. Makes a massive difference to the friction on the drum end. I bought it a couple of years ago and again gave it to AB as I have gone a Deltatek Air Freespool.
  18. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Rossco (13th July 2015)
