Page 134 of 570 FirstFirst ... 132133134135136 ... LastLast
Results 1,331 to 1,340 of 5693
  1. #1331
    Hunter
    expect some different noises, they are all normal for a forced induction motor
    Thanks for the heads up misses said it was making some strange noise, when I fitted one to my 4.2 gu cant say I noticed any difference although I always suspected it was choking air flow
    GU8 Simpson Pack-Auto 2" lift, Dual Batts
  2. #1332
    Engine kit with ceramic pistons, oem td42ti head and parts, also a Redarc dual oil pressure/ water temp gauge and dual volt gauge.
  3. The Following 6 Users Say Thank You to mudski For This Useful Post:
    cgm (9th July 2015), Hodge (9th July 2015), lucus30 (9th July 2015), Rocket55 (9th July 2015), Rossco (9th July 2015), Stropp (11th July 2015)
  4. #1333
    177 Post(s)
    That sentence alone would put a huge dent on the wallet. lol
    Meh! I have gotten over thinking too much on the costs. It was doing my head in. I know im up for a pretty penny, thats what comes with a build and conversion. I prepared myself, but at the same time im trying to keep costs down without jeopardizing the end result. To much....
  6. The Following 3 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (10th July 2015), Hodge (9th July 2015), Stropp (11th July 2015)
  7. #1335
    Sounds like it's going to be a solid reliable engine.
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
    threedogs (10th July 2015)
  9. #1336
    Ceramic pistons is a great touch, You'll also require that ceramic coated dump
    pipe like Cuppa has, I liked that alot. Its ok Mark I could spend your money all day
    and not even flinch lol
  10. #1337
    My Fairline scoop arrived today. Picked up the Redarc dual oil pressure/ water temp gauge and also the dual volt gauge, annnnnd GU td42t vacuum tanks and hoses etc etc.
    threedogs (15th July 2015)
  12. #1338
    DTS Exhaust manifold.... I hope Cross country hurry up with the cooler. And Killa with the loom.
    Hodge (16th July 2015)
  14. #1339
    177 Post(s)
    It's slowly coming together Mark.
  15. The Following User Says Thank You to Hodge For This Useful Post:
    mudski (16th July 2015)
  16. #1340
    When I ordered with them I was told 4 weeks turn around, it took about 12.
