Results 1 to 8 of 8
Thread: Water in fuel question / water in fuel warning light?
    Apr 2011
    Vic, NT, Tas - On the move with work
    Hi guys, I have just bought a 96 GQ Patrol 4.2 TD 330k on the clock. The water in fuel light has come on. It wasn't on when i bought it but only a few hours later when it was home i went to start it again the warning light was showing and the charm sounding when i turn the ignition off. Today i opened the bottom of the filter and drained the water until i got strait diesel. Some other mold like bits came out too.
    The problem is the light is still on. Is this normal? Does it go off after a period of time? Im worried to drive it with this light on in case i irreversible damage.
    I have just bought a CAV fuel filter to go in which fits into the original head in the hope that i can monitor the water contamination without relying on the warning light.
    Looking for your opinions and experience on this issue.
    Thanks.
    Feb 2011
    Shed
    45 Post(s)
    Gday burden i'd be changing that fual filter ASAP if theres crap in their mate and maybe check the tank did you run it real low couldav picked up allsorts
  3. The Following User Says Thank You to growler2058 For This Useful Post:
    Burden (5th April 2011)
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Agree, change the original filter and install the CAV. I believe they go before the original filter but I've heard of guys having them behind as we..
    ________________________
    ______ 2017 D-Max _______
  5. The Following User Says Thank You to Maxhead For This Useful Post:
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by nisspat View Post
    agree, change the original filter and install the cav. I believe they go before the original filter but i've heard of guys having them behind as we..
    x2 mate as soon as posible ,pay to get a couple of filtersand put some desiel treatment thru the system
  7. The Following User Says Thank You to Sir Roofy For This Useful Post:
  8. #5
    Apr 2011
    The idea behind getting the CAV was so i could do few filter changes cheaply and keep a good eye on it until its sorted out. The CAV i just bought today over the phone from 4WD systems in SA and they are posting it out tomorrow. Its a type which screws into the old bracket so i can retain the priming pump.
  9. #6
    Apr 2011
    When you say fuel treatment Roofy do you mean the flash lube stuff? Do you reckon i should drop the fuel from the tank only 10 litres in there or so.
  10. #7
    TRAFALGAR VIC
    35 Post(s)
    Thats fine mate but if you got crap comming out the old filter,theres a good chance theres crap up the fuel line as well
    after you trat your fuel you might need to change the filter ,anyway read the directions on the bottle
    good luck
  11. #8
    TRAFALGAR VIC
    35 Post(s)
    Up to you mate might pay to do it,the water if any will settle on the bottum so you can drain of the good stuff
