Page 525 of 1057 FirstFirst ... 523524525526527 ... LastLast
Results 5,241 to 5,250 of 10565
  1. #5241
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Put the compressor in today, still need to finish off a bit and put switch in place but all works. Attachment 59313
  2. The Following 3 Users Say Thank You to Covo71 For This Useful Post:
    Rocket55 (30th June 2015), Stropp (1st July 2015), threedogs (30th June 2015)
  3. #5242
    Removed the wiring loom from the ecu and engine and packed it up to send off. Also removed all wiring/ birds nest from the aux battery going into the cab. There was so many wires i couldnt remeber what these wires were for. Now im left with a gaping hole in the firewall loom boot.
    Once the conversion is done, i will re wire the enitre aux side and what ever was attached there and put the aux back in.
    Hodge (30th June 2015)
  5. #5243
    Patrol Guru Rocket55's Avatar
    Sydney
    Quote Originally Posted by Covo71 View Post
    What size wire did you run down to the back for this?
  6. #5244
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    new bonnet struts.. lazy 25 bucka eBay spesh... so much better then using vice grips before..
  7. #5245
    Quote Originally Posted by mullet_hunter View Post
    And copping a bonnet to the head...
  8. #5246
    Re mounted my ECU-talk and fabricated three brackets so the awning will sit level with the gutter.
    going to re-think the gauge side of things, happy as with the awning set up.
    No metal on metal contact anywhere.
    my icv% is still reasonably high
    Hard ware will be changed to allen round head stainless bolts nuts etc.
  9. #5247
    Patrol Guru
    Jul 2014
    6 Post(s)
    Dismantled Runva winch for a clean and regrease. Was so clean inside I needn't have bothered, surprising considering she's been swimming a few times.
    Stripped and cleaned it all, and a regrease anyway, since I had it all apart. Parts cleaner would come in handy, but ah well, easy job.
  10. The Following 3 Users Say Thank You to Throbbinhood For This Useful Post:
    AJTich (8th July 2015), Rocket55 (1st July 2015), threedogs (1st July 2015)
  11. #5248
    Dec 2012
    Coffs Harbour
    Quote Originally Posted by Rocket55 View Post
    Just used an 8 gauge to a distributor block. I might swap it out for a 4 gauge though.
  12. The Following User Says Thank You to Covo71 For This Useful Post:
  13. #5249
    Expert graeme1969's Avatar
    Jun 2013
    Wesley Vale, Tas
    Quote Originally Posted by Throbbinhood View Post
    Gday,
    Just wondering what model Runva you are running, and has it done everything you have asked of it?
  14. #5250
    Patrol Guru
    Jul 2014
    6 Post(s)
    Quote Originally Posted by graeme1969 View Post
    Gday,
    Runva 11xp. Everything and more. Been used underwater a few times, and like I said, water ingress was at a minimum (tiny bit of grease discoloration near the free spool lever).
    They come with great warranties and well priced. 10/10 would buy a again!
  15. The Following 2 Users Say Thank You to Throbbinhood For This Useful Post:
    AJTich (2nd July 2015), graeme1969 (29th July 2015)
