Page 520 of 1057 FirstFirst ... 518519520521522 ... LastLast
Results 5,191 to 5,200 of 10566
  1. #5191
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Fixed it up. I will put up a DIY panel beating thread later - much later.
  2. The Following 4 Users Say Thank You to 4bye4 For This Useful Post:
    Clunk (24th June 2015), Stropp (22nd June 2015), threedogs (24th June 2015), TPC (22nd June 2015)
  3. #5192
    Finally go around to rewiring my trailer plug and got rid of those stupid plastic clips.
  4. #5193
    Expert Dman2603's Avatar
    Mar 2015
    Perth SOR
    From this happening
    To this
    & the big Stripout is nearly complete!
    2006 GU IV ST MAN 3.0TD - UHF, Boost & EGT Gauges, NADS, Pro Vent 200, Snorkel, Tigged IC, 2" Lift, Dual Battery System & Still lots to come!
    Got a Patrol in WA CLICK HERE - Just Go There!
  5. The Following 2 Users Say Thank You to Dman2603 For This Useful Post:
    4bye4 (24th June 2015), Clunk (24th June 2015)
  6. #5194
    Quote Originally Posted by Dman2603 View Post
    From this happening
    To this
    If you have plastic plugs in the floor can I suggest you remove them
    if you intend doing bogholes all the time, There is a great lift up drain plug the Comp guys use
    may be of some good to you.
    Dman2603 (24th June 2015)
  8. #5195
    Just do what the guys in Top Gear did, just shoot a hole into the floor with a rifle hahahahaha
  9. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    Dman2603 (24th June 2015), threedogs (24th June 2015)
  10. #5196
    Quote Originally Posted by 4bye4 View Post
    I know someone with some spare rear bumper lights if you need them mate
  11. The Following User Says Thank You to Clunk For This Useful Post:
  12. #5197
    Best thing you can ever do, and if anyone reading this
    has scotch locs connecting any wires on their Patrol,
    Remove them and solder the wires properly and use heat shrink to
    complete the job. THEY WILL FAIL
    http://www.ebay.com.au/itm/20x-Scotc...item2ecd9f7d94
  13. #5198
    Aug 2014
    Kingsley WA
    15 Post(s)
    Thanks clunky but the lights are ok its the bloody plastic bum per that I have got to repair. Moral to the story, if the distance between the ground and the exhaust is less than the hole your driving into, then get a lift kit.
  14. #5199
    I wonder if Howezit still has his old bumper, he was trying to sell it a few months ago, might be worth asking
    Are you sure you won't have a couple of lights as spares???? lol......... They come in ve3ry handy let me tell you hahahahaha
  15. #5200
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    I've just silaticed them into the bumper. They even stay in after mudding....
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
