It wont be the differance betwen the 40 / 80 channel rigs as long as they are on the same channel. (and between channels 1 - 40)
40 - channel reciveing a transmission from an 80 channel - the recived audio is lower
80 - channel reciveing a transmission from an 40 channel - the recived audio is higher, worst case you could get some audio blocking (bit of no audio). But most of the cbs are desiggned to prevent this.
How i it transmiting? do you have good range - can others hear you a km away? - as you might have a staffed antenna / cable / connector (most often a connector fault).
When you tap the button and stop the static, do you then hear ok?
Or are you activating the tranmitter?
