Page 518 of 1057 FirstFirst ... 516517518519520 ... LastLast
Results 5,171 to 5,180 of 10566
  1. #5171
    Hopefully wire up some lights on my roof rack.
    Weather permitting
  2. #5172
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    Wired up my roof lightbar...BRIGHT.....and found two Hercules 8000 lb snatch straps in my Recovery gear to return to 4wd Supacentre. Has anyone else returned yours? Did you get a replacement? I have to send mine from Adelaide.
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
  3. #5173
    Quote Originally Posted by AJTich View Post
    Get your money back and buy from one of the Big three, TJM, ARB or Opposite Lock
    Dont buy cheap recovery gear, its cheap for a reason
  4. #5174
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Installed my adjustable draglink, went down the road to get wheel alignment but they too busy
    ________________________
    ______ 2017 D-Max _______
  5. #5175
    You can do it yourself with a long bit of rod, front inside of front rim and rear edge of front rim???
  6. #5176
    ACT
    Yeah I know mate, I've got it pretty spot on. I'm not using the troll so I'll wait till Monday and get it done properly on a machine
  7. The Following User Says Thank You to Maxhead For This Useful Post:
    threedogs (20th June 2015)
  8. #5177
    Nov 2013
    Gold Coast
    Fitted a new section of vacuum hose from the brake vacuum tank to the metal pipe after removing the old piece with a "tee" fitting that used to power the old cruise control now upgraded with a new unit.
  9. #5178
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    new springs and shocks, some of the dynamatting is done
  10. #5179
    Oct 2013
    Andrews Farm
    Agree about cheap. These were "freebie" additions to roof awning and something else. My other two are Nobles ones.
    AJTich
  11. #5180
    Patrol Guru Rocket55's Avatar
    Sydney
    Gave it some fresh Delo oil, a couple of filters, fuel filter and air filter. It'll get a grease tomorrow.
