as above Dom,
best way to go is buy a BIG bottle of brake fluid
undo the nipple on the passenger rear
pump ALL the fluid out (into a container) - just keep pumping the pedal and keep going for a bit after the Master Cylinder is empty
when your happy, add new fluid
keep pumping
when thats empty
fill up again, and get a mate to help you bleed the brakes properly
none of this Supercrap "self bleeding kits"
get a mate on the spanner
3 pumps on the pedal, holding pedal on the third pump - let the fluid out - pedal goes to floor, mate locks bleeder nipple, pump again, and again and again
(I always go for 3 or 4 times per wheel, until new clean fluid is coming out )
ALWAYS start at the nipple furthest away from Master Cylinder
so
passenger rear
drivers rear
passenger front
drivers front
if your getting AIR or crappy old fluid - keep going until its clean new fluid with NO air
