Results 1 to 10 of 16
Thread: gasmixer
Threaded View
  1. #2
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Hey mate - don't have a photo, but mine is a small, black cylindrical unit on the inlet pipe from the compressor unit. It has a wide chisel tip slot in it that you can use a screwdriver to adjust. What do you need to do? The lights/gauges on your LPG monitoring unit (under the bonnet also usually - on the firewall on the passengers side) should tell you whether it's running rich or lean and cycling back and forth between the two as you increase, maintain and decrease throttle.
  2. The Following User Says Thank You to Bigrig For This Useful Post:
    paul1351 (6th April 2011)
