Bloody good idea. Plenty of room for it too. Just took the two aluminium trays out and all there is on the top is a piece of batt type insulation, same with the bottom one although that has the connection to the peltier.
Might look at this one:
http://www.ebay.com.au/itm/12V-60W-T...item2a49e63f0e
and maybe improve the insulation a bit.....![]()
GROOVY GUVII
Mate, that's a top idea and for a few bucks can't go wrong bonus is all up it will still be less than $20.
Did some measurements on it using a 12v battery (no engine running). It pulls 13 amps for about the first minute, it then settles down and pulls between 7 and 8 amps and pretty much stays there. I'll try it for an hour and see if it varies much. It would be interesting to find out which peltier they put in it as it seems results vary a lot, on some (like mine), the original wiring gets very hot, others don't...
I'm going to power this oven via a timer, sort of set and forget. Looking at something like this.....
http://www.ebay.com.au/itm/371220962...%3AMEBIDX%3AIT
GROOVY GUVII
mudski (26th June 2015)
Its only a small Peltier I reckon. The 40W one I have here is twice in size. Unless you can get long and narrow Peltiers. As they use something long a narrow in these ovens.
Does the timer make a "ding!" when it runs out of time? Lol.
clubbyr8 (27th June 2015)
Yeah it's a long narrow one but it still pulls a lot of current, after running it for 70 mins, it was still pulling 6 amps which at 12.2v is approx 73w. Assuming it is a Peltier as there doesn't seem to be a cold side and there's no fan to get rid of the cold air.
Nor sure if the timer makes a ding but it has a pretty blue led......![]()
GROOVY GUVII
