I reckon so, but you may want to consider an additional bracket to support the extra weight. I was really hanging off the screws and as you can see, they're so tight that the bottom of the hose clamp has flattened against the bottom of the bracket.
One other thing I didnt mention, make sure you use the tube at the end for the rear bracket. I used one that was a couple from the end (for some silly reason, probably rushing the job) and the overhang on the awning exceeds the maximum recommended 700mm (mine is 740mm). So ill move mine toward the rear. Foxwing may have a different maximum overhang.
