Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Cracked diff case
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    Mig tig or stick it doesn't matter it'll all do the job if prep is right. And just disconnect the battery then you can weld it on the car
    Such is the rule of honour.
  2. The Following User Says Thank You to macca86 For This Useful Post:
    MudRunnerTD (14th June 2015)
  3. #12
    Expert Lawrence's Avatar
    St Thomas, Jamaica
    Quote Originally Posted by macca86 View Post
    Thanks Macca86,
    1989 Nissan Patrol DX with the td42 (inline pump). No mods yet except black US 16x8 rims with 265 75 16 Ats
  4. #13
    I would maybe leave the diff oil in to and drain and replace on completion as the oil will absorb some of the heat. Diff oil is very thick so as it heats it will thin out . It looks like most of it leaked out anyway.
    Good luck. As Macca said, any type of welding will get it done.
