Page 509 of 1057 FirstFirst ... 507508509510511 ... LastLast
Results 5,081 to 5,090 of 10566
  1. #5081
    Far out mate, huge improvement!
  2. #5082
    Patrol Guru Rocket55's Avatar
    Sydney
    Quote Originally Posted by Jodaniels View Post
    i finally changed my leaking intercooler and went from 16.8l/100km to 12.6l/100km . yep should have done it 2 years ago..
    What did it sound like?
    I can't see any visible signs of a leak in mine but it does make a noise like a lot of air rushing around inside and empty vestibule when the boost rises.
    Cheers Rod
    My Build 2005 TD42TI
  3. #5083
    nothing GGGRRRrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrr
  4. #5084
    Expert Dman2603's Avatar
    Mar 2015
    Perth SOR
    Not today but at the weekend fitted the snorkel! But now I have that "ahhhhballs" feeling did I retighten all the clamps!!
    2006 GU IV ST MAN 3.0TD - UHF, Boost & EGT Gauges, NADS, Pro Vent 200, Snorkel, Tigged IC, 2" Lift, Dual Battery System & Still lots to come!
    Got a Patrol in WA CLICK HERE - Just Go There!
  5. The Following User Says Thank You to Dman2603 For This Useful Post:
    Clunk (14th June 2015)
  6. #5085
    WA Wheatbelt
    23 Post(s)
    Yesterday I had both tie rods and steering damper changed and wheels rotated and a wheel alignment done.
  7. #5086
    84 Post(s)
    Got all of the wheels balanced.
    The thrumming noise above 80kph
    has gone. It is amazing how you
    get used to a noise as it
    progressively gets worse.
    While I was at the tyre joint,
    I got to compare the treads
    on a set of maxxi bighorn
    mud terrains and BFG
    mud terrains.
    Apart from a few minor
    differences, the overall
    tread depths and patterns
    seem to be of similar design.
  8. #5087
    And the headache begins... gonna swap over intake manifold, new glow plugs and injectors.
  9. #5088
    Ugh! First hiccup. Different stamped letter of the new to old injectors.
  10. #5089
    Patrol God Stropp's Avatar
    38 Post(s)
    picked uip the patrol after the service and investigating the grinding sound from the front end, seems that when i had the last wheel alignment they screwed the bump stop bolts back in so when i put the 35's back on the lugs on the muddies were running on the suspension arm, screwed them back out and the noise is gone, bit of a shiny spot on the arms but no damage to the tyres
  11. #5090
    WA Wheatbelt
    23 Post(s)
    Cut my losses and bought this dash cam
    http://www.sportgps.com.au/blackvue-...-dash-cam.html
    I installed it all by myself, too. lol
  12. The Following User Says Thank You to DX grunt For This Useful Post:
    Stropp (13th June 2015)
