Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: What is this?
    Legendary dom14's Avatar
    38 Post(s)
    BTW, my old shrink said that my recent problem of missing words in written sentences isn't a bad thing. Apparently it happens to him too.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. #22
    38 Post(s)
    I"m glad it's not a left over piece from a old time bomb. I was anxiously wondering whether it is a wireless transmitter to activate the bomb.
    Cheetah Outreach
  3. The Following User Says Thank You to dom14 For This Useful Post:
    Clunk (10th June 2015)
  4. #23
    38 Post(s)
    the charcoal canister is what the fuel tank breathes through, the rough idea is that the charcoal will absorb the vapours from the tank and its also plumbed into your intake allowing the vapours to be burnt when the engine is running. its an emmisions thing
    if you remove the canister you will see a little tube sticking out that goes down into that cover you were asking about
    Hi Billyj, I'm just wondering mate, do I need to service the charcoal fuel vapour canister?
    For example do I need to unclog it?
    The "vacuum advance" at when cold start doesn't seem to be working.
    Engine is idling at around 500-600 rpm or so.
    I'm wondering whether a vacuum leak from the canister is causing this.
    For example, I'm guessing there's a valve somewhere in the canister to allows the vapours to get into the inlet manifold, but not
    the other way around.
    Can that valve be faulty or clogged up from years of petrol fume junk?
    Cheetah Outreach
  5. #24
    Expert billyj's Avatar
    gordon
    shouldnt need any service. on my tb42e the valve is controlled by an electric solenoid at the engine
  6. #25
    38 Post(s)
    Ok, cool. I think mine is the same.
    How about the canister itself?
    Even if it doesn't to the job it suppose to do due to clogging, it shouldn't affect the vacuum advance system, should it?
    Cheetah Outreach
  7. #26
    gordon
    nah shouldnt affect it
  8. #27
    38 Post(s)
    Cool!. I won't be fiddling with the charcoal canister then. I'm happy to leave it alone, where it is, as it is.
    Cheetah Outreach
  9. #28
    38 Post(s)
    Hi Billyj,
    Can you please have a look at this thread and post an opinion or some tips mate?
    http://www.nissanpatrol.com.au/forum...730#post609730
    Thanx
    Cheetah Outreach
  10. #29
    Nov 2020
    Ecuador
    If the carbon canister isn’t connected to the vacuum, can that have a negative effect on emissions?
  11. #30
    Yo DOM14 , good to see you grabbing the spanners and
    doing stuff your self, very rewarding IMHO TD
