Page 124 of 570 FirstFirst ... 122123124125126 ... LastLast
Results 1,231 to 1,240 of 5693
  1. #1231
    476 Post(s)
    New squirters for the Dunger! Got my new glow plugs, a nice and clean intake manifold, now just to find the time to put all this in. Dunno about the glow plug timer mod though, I'm skeptical this is really needed with metal tipped glow plugs.
    Hodge (2nd June 2015)
  3. #1232
    Im still on my OE glow plugs and just about to change after 200k I'll do it again at 300k if it makes it.
    Got an email from extrem4x4 about slotting in a BMW 3ltr single turbo Thinking Ill go that way
    as I can source motor easy through a mate, Extrem sell kits with engine mounts the works.
  4. #1233
    176 Post(s)
    Is this for the 4.2 or the zd ?
    Last time I was at yours you said no more $$$ to be spent on the grenade... All proceeds direct to the 4.2 from here on in !
  5. The Following User Says Thank You to Hodge For This Useful Post:
    Bloodyaussie (2nd June 2015)
  6. #1234
    476 Post(s)
    For the zd mate. its really over due and i need to keep this motor going as good as possible until the funds are adequate, which still is a bit away. But getting closer.
    Preventative maintenance I suppose you call it.
  7. #1235
    My hand metal detector arrived , I know it works cause I tried it on my inplant.lol
    The idea is Im going to use it when I good gold Panning with family 4x4 .
    when Im up to it of course, coil is about 5" across, and adjustable as well
    Also a few different rear cameras have arrived, one is billet alloy,
    the other with a bit of work will replace the numberplate assembly
    depends which gives better view ,will be the one Ill fit, well hopefully
  8. #1236
    476 Post(s)
    Sorry what are you doing with the bmw?
  9. #1237
    176 Post(s)
    I think he is putting it in place of the ZD30.
    Advanced dave97's Avatar
    Jan 2015
    Not for the patrol but will probably use it while working on the patrol
  11. The Following User Says Thank You to dave97 For This Useful Post:
    93patrol (6th June 2015)
  12. #1239
    As I have a mate that wrecks BMWs it might be an option for me if the motor goes.
    They make great power apparently
  13. #1240
    WA Wheatbelt
    23 Post(s)
    Bought myself a dash cam with front/rear camera, including speed/gps thingie.
