Page 508 of 1057 FirstFirst ... 506507508509510 ... LastLast
Results 5,071 to 5,080 of 10565
  1. #5071
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    Yeah Turtle. . Be good to see it all...and then out onda tracka when done...
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
  2. #5072
    Plan is to finish off my rear cargo shelf, ready for powder coating on Tuesday
  3. #5073
    Last night I did the GU hub nut upgrade, bloody heaps better design than the GQ system
  4. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    lucus30 (5th June 2015), Parksy (5th June 2015), threedogs (5th June 2015)
  5. #5074
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    That it is. Keeps your wheel bearings nice tight, I know lots of people have issues with the old system loosening off
    Lucus30's 1999 GU ST TB45E
  6. #5075
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    I max 12000lb winch fitted to winch cradle. winch $399, cradle $295 lets see how long it lasts. my theory is if it pulls me out of the sh#t once and dies it has still paid for itself.IMG_3492.JPG
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  7. #5076
    Made a bracket for the ECU talk and fitted it up. Took a whole five minutes....
    I then contemplated installing the new squirters, glow plugs and clean inlet manifold, but its too bloody cold in the garage...
  8. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Hodge (5th June 2015), Parksy (5th June 2015)
  9. #5077
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    That is nice mudski. Gonna have to reposition mine in a similar way to yours. I like it.
    IMO and should be taken with a grain of salt.
  10. The Following User Says Thank You to Parksy For This Useful Post:
    mudski (5th June 2015)
  11. #5078
    Cheers mate.
    I just had a piece of black pesrpex here, got the dremel out and cut a section off, got the gas soldering iron out, put the torch tip on, put the plastic in the vice, heated up along the perspex and bent it up. I had some tiny bolts here to attach the bracket to the display, then some double sided tape to stick it down on the dash.
    The bracket really needs a small foot at the front of it too as the weight of the ECU talk wants to pull it forward if you know what I mean. Dunno how long the tape will hold though.
  12. #5079
    Feb 2015
    I've parked the trol in the MUD at work.
    When trying to go home i got stuck :-).
    Driving home with mud on the side just for fun.
  13. The Following User Says Thank You to dennis77 For This Useful Post:
    Hodge (7th June 2015)
  14. #5080
    i finally changed my leaking intercooler and went from 16.8l/100km to 12.6l/100km . yep should have done it 2 years ago..
  15. The Following User Says Thank You to Jodaniels For This Useful Post:
    threedogs (9th June 2015)
