Page 39 of 50 FirstFirst ... 3738394041 ... LastLast
Results 381 to 390 of 498
Thread: Outback Ideas Recovery points
  1. #381
    I still have and use that hook on the back of my Patrol, its earned its keep.
    As some know trying to get my roof rack fitted this Saturday, after its on Ill fit my wheel hoist
    and do a video I can put here to show you how easy it is to get a wheel from the roof rack to the
    ground using only your thumb.
  2. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Dman2603 (4th June 2015), Irish (11th June 2015)
  3. #382
    BiPolar Fool BSRT.Beast's Avatar
    Apr 2015
    Keysborough
    4 Post(s)
    I'm looking for bolt on without to much hassle recovery points for this old style arb winch bar
  4. #383
    hi BB PM sent
    The easiest solution is to replace the OE hook with my
    12mm thick flat plate again very strong.
    You can also if you want bolt a 10,00lb black hook to
    it as well.
    To fit two you'll need to drop the bullbar and make a plate with three 14mmx 1,5 nuts welded to it.
    IMHO not the best snatching from only one side, a bridle from two points would even out the weight better.
    BSRT.Beast (11th June 2015)
  6. #384
    Nov 2013
    QLD
    any updates on the video mate?
  7. The Following User Says Thank You to dannypatrol For This Useful Post:
    threedogs (14th July 2015)
  8. #385
    Been slack as mate and too sore.
    But you've given me a reminder to get off my butt.
    Need some heavier "U" bolts and thats about it.
    I'll go to the bolt place tomorrow and see what they have.
    thanks.
    Might see if Simon from 4WD tv can do a video on it for me.
    dannypatrol (15th July 2015)
  10. #386
    Hi folks,
    3d is staying on for yet another year as vendor!
    Thank you for your ongoing support John
  11. The Following 4 Users Say Thank You to AB For This Useful Post:
    Rocket55 (19th August 2015), rusty_nail (19th August 2015), Sir Roofy (19th August 2015), Winnie (19th August 2015)
  12. #387
    well done TD! oooo i actually got some money back from tax that the missus dont know about. ill hit you up for some points, been meaning to for ages
  13. #388
    Hi Rusty I'm pretty sure the "T" shaped one will suit you set up,
    double check tonight, the folded style fit under the chassis rails
    sms sent lol,
    Computer on last legs and why bloody not
  14. #389
    Hey John,
    Can you PM me some info as to what I need for my GQ, Millweld bullbar if that makes a difference with pricing.
    I've been thinking about it for a little while, front recovery points, one each side.
  15. #390
    Not sure how the Milweld mount, can you see
    the three holes either side of the inside chassis.
    Do you have a close up pic in your build thread I can look at?
