Ok so I just took it for a really sneaky drive around the block at lunchtime...
Its running ok, I didn't go to far as I have no intercooler hole cut yet and as BA said I don't want it getting too hot.
Things I have noted....
1 My rev counter works but only past 2500rpm, I suspect the sender is RS
2 I may put in another vac canister as a precaution but not sure at this stage
3 The motor seems a little down on power and I only made about 7psi boost so I may need to increase the soot a little via the smoke screw
4 It sounds frigging awesome with no mufflers and only a short stubby pipe fitted to the dump pipe.. lol
5 I really want to cut a hole and fill the bonnet groove so the top mount cooler can be fitted and looks awesome but need someone who is a panel beater or body work specialist to help me/ do a paid job cos this is cosmetic and in full view so I don't wanna f-it up
Then a bit of fine tuning, fit an exhaust then a visit to VASS & vic roads. Then Done.
BTW insurance - - Shannons were awesome, full off road cover anywhere in AU and fully comp with full modifications and agreed value...
