Page 504 of 1057 FirstFirst ... 502503504505506 ... LastLast
Results 5,031 to 5,040 of 10566
  1. #5031
    So no idea what happened, thats spooky lol
    I have a theory/ idea of why?
    A few days before I changed my air filter lid seal. And when this happened on the freeway, I noticed as soon as I popped the bonnet up the hose that runs from the top of the radiator to the top pressure tank on the LHS move. My only theory is that I had somehow folded or wedged this hose and blocked of the hose. There for not letting the radiator and cooling system relive the excess pressure to the top tank. The pressure was so great in the cooling system, the bottom hose clamp, which is the OEM spring loaded clamp type, opened up momentarily, the excess pressure was relieved( hence the coolant all through the LHS wheel arch) and then simply closed up again once the pressure was gone.
    I was bloody lucky I didn't bust anything.
    lucus30 (22nd May 2015)
  3. #5032
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    If thats all it is mate you are very lucky. I guess no TD42 transplant after all
    Lucus30's 1999 GU ST TB45E
  4. #5033
    I think you mentioned that when it first happened. Lucky it shut down in time
  5. #5034
    My new[2nd hand] roof rack has now been modified, lights fitted
    F&R and sprayed gloss black, as Matt black turned to shite very quickly,
    and is ready to fit, Have a few coming over to lift it on this arvo, well thats the plan.
    Taped some "U" shaped rubber for the feet to cushion the gutters.
    As it came off a GU it should not need any adjustments, the wait is on lol
  6. #5035
    Aug 2014
    Perth
    10 Post(s)
    Wired up some reversing lights, can't wait for it to get dark so I can see how much light I have
  7. #5036
    Feb 2011
    Shed
    45 Post(s)
    Replaced belt and tensioner pulley.
    Belt looks fubar so another call to patrolapart tomorrow and order that
    Tell ya what there was no way known that bastard was gunna be moved with a ring spanner to take the tension off
  8. #5037
    Fitted up the 37s and fitted new brake pads to the back of the GQ!! Need to rethink the flares!! No where near it!! These Treps are huge!!!!
  9. #5038
    Yeah I need to find a millisecond to start this TD build...
    This is one thing I do like about the ZD's. You lose water, it shuts down.
    lucus30 (24th May 2015)
  11. #5039
    Installed the tweeters /piezio speaker about mid way up the Pillar moulding what a pitb job.
    think I'll go to the speed shop and grab a can of spray paint to match the moulding.
    Over all happy with the way it worked out, I'll put a pic after I spray them
  12. #5040
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Did you get the roof rack on yet?
