Page 106 of 187 FirstFirst ... 104105106107108 ... LastLast
Results 1,051 to 1,060 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1051
    Well found a couple of hours to work on the GQ today. I don't have a shed that it fits in so its a pain in the ass to get stuff done!. Grrrrrrr!
    Finally dragged out the Treps for a look.
    Took the opportunity to replace the rear brake pads too.
    I fitted the wheels up for a look but will need to take them off to sort out the guard chop. It turns out the rims are a big offset coupled with the wider GU Diffs and I have to strip off the flares and find some really really fn big flares!!!
    Holy shit!!!!
  2. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    93patrol (25th May 2015), AB (24th May 2015), Bloodyaussie (24th May 2015), threedogs (25th May 2015)
  3. #1052
    Your Simex's are teeny tiny... Hahaha
  4. #1053
    If you do go the 150mm edging then tight spacing on the fixings mate, they look pox when lazily put on.
    Pretty serious tyres though, definitely not a daily driver anymore
  5. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (24th May 2015)
  6. #1054
    need to do a bit more research on the flares. i might even have a look at those moulded ones on ebay? how wide are they? need 115mm!!
  7. #1055
    No idea but ask Robbo_ he has them.
    Check that thread about td fuel consumption there's a pic of his gq on there.
  8. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (25th May 2015)
  9. #1056
    Are you moving the rear diff back a touch??
  10. #1057
    Thanks AB i have sent him a PM
  11. #1058
    No.. I would have to buy longer lower arms to do that. in fact i am going to make a slight adjustment to my uppers that will move it forward slightly as i noted there was a rub mark on the Amadas from the spring at full flex.
  12. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    93patrol (25th May 2015), threedogs (25th May 2015)
  13. #1059
    22 Post(s)
    Where exactly are the springs rubbing on the shock? To me it looks like you have stock length lowers?
    96 GQ coil/Cab
    08 G6eT
  14. #1060
    Yes mate stock length lowers. I was surprised but had a look and my pinion Angie is pretty straight, I mustnt have made an adjustment when the new lift went in, I will shorten the uppers a degree and will then clear the springs.
