Results 1 to 10 of 24
Thread: DieselCare fuel manager filter - GU ZD30
Threaded View
  1. #9
    177 Post(s)
    Quote Originally Posted by Rock Trol View Post
    Hey Hodge, do you have a lift pump? Also are you using the shorter filters? What micron?
    When Hi Tech Diesel installed mine they put it over on the other side where the ABS would be if I had it. It was before the OEM filter. I had the longer cartridges at 5 microns and the pump was having trouble sucking fuel through it. You could hear a sucking noise as you accelerated. After 5000 km I took it off and the car went like a scalded cat.
    Mine is after the OEM filter. It sits between the main filter and the IP. It is a 2 micron unit. I have not noticed a single bit of performance variance after I fitted it, and I don't have a lift up mod but it is on the to do cards. As I mentioned in my edited post above, i believe it does drag the IP, so a lift mod is a must.
  2. The Following User Says Thank You to Hodge For This Useful Post:
    Rock Trol (20th May 2015)
