Results 1 to 4 of 4
Thread: how to fix gq clock
    Apr 2015
    west of brisbane
    how to fix gq clock
    i dont know if this will help anyone but i have 2 gq patrols and both their clocks didnt work. so i removed them , just had to pull the panel out far enough to get stumpy phillips in to remove clock. the panel has 4 screws at the top vents,4 screws from the sides and 1 behind ash tray. clock has 2 screws and comes apart pretty easy. both of mine just needed one resistor re-soldered. this is shown in pics.20150518_182839.jpg20150518_182904.jpgthe solder joints looked okay but after being re-soldered., the clocks work fine.
  2. The Following 5 Users Say Thank You to carsurgeons For This Useful Post:
    Chimo (27th September 2015), Clunk (18th May 2015), graeme1969 (18th May 2015), mudnut (1st July 2015), NissanGQ4.2 (18th May 2015)
    Mar 2015
    so was it a dry joint or had it damaged the pcb ?
    Advanced awloelxf's Avatar
    Jul 2015
    Russia
    Thanks, will try.
    Apr 2015
    west of brisbane
    hi i say it is a bad joint due to heat. i did 2 clocks and both were fine after re-solder
