Results 1 to 10 of 14
Thread: Connecting Off road lights to high beam
    Advanced Ted's Avatar
    Mar 2011
    NSW
    Hi guys, after having used the search button extensively i'm abit lost as to how im going to do this.
    I've got 2 extra lights mounted on my bullbar and want to connect them to the high beam switch on my headlights. So when I flip on my high beam the lights are activated also. as I dont have a multimeter to see what cable does what i'm abit lost as to what connects to what.
    I've noticed that behind the regular headlights there are 3 cables which connect into the headlight, im assuming 2 are pos/neg and 1 is an earthing wire, or is the 3rd wire to activate the high beam?
    Also, if I connect the off road lights directly to my headlights will I need to worry about overloading the fuse when running high beam for extended periods longer of time?
    The lights came with wires, connectors, a relay and a switch (however I prefer using the high beams over a switch)
    Much appreciated,
    Ted
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by Ted View Post
    Much appreciated,
    Ted
    They can be connected to your headlights highbeam mate, but will need a separate fuse and higher amp wire than the headlights ... Have a hunt through search as I'm pretty sure I've seen wiring diagrams for spotties on here.
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Mate, the two pins are hi and low, the other is neg. If you hook up directly the the high beam wire without a relay on each light, you will melt your control switch on the steering wheel.
    You can use the high beam wire at the back of the light to activate the relay, and you will also need a seperate power feed to the relay to power the spots.
    You would be best advised to take it to an auto electrician, that way you only pay once. Cheers.
  4. The Following User Says Thank You to the ferret For This Useful Post:
    the evil twin (2nd April 2011)
    Jul 2010
    Waterford West Qld
    So to take Ferrets advise down to a total novice understanding is as follows:
    yes you can go directly off the high beam activation wire
    but you need to run aminimium 30amp relay to supply the power to your spot/driving lights
    this would be a 5 post relay (1.positive feed 2.positive switch feed 3.earth 4&5. feed to lights)
    you will also need a switch to control the spot/driving lights independantly to your headlights inside your cab
    if you don't feel confident doing this, pay a pro, if you have everthing prepared ( lights fitted, hole for switch in cab) this will help keep price down.
    Hope all this info from Big rig, ferret and I helps.
    Tim
  6. The Following 3 Users Say Thank You to Finly Owner For This Useful Post:
    the evil twin (2nd April 2011), the ferret (2nd April 2011), ute351 (3rd April 2011)
    The 3 pins are Hi beam 12 Volts, Lo Beam 12 Volts and common Earth clockwise from front but use a multimeter to confirm.
    Buy a 5 post power relay as others have suggested... BUT check that it is a power relay and not a changeover relay. they look the same but will be marked on the packet.
    Just behind the headlight splice a wire into the Hi beam 12 Volts to switch the relay but run that wire to a manual switch in the cabin and back to the relay so you can isolate the relay or your illegal for road use IE you don't want those lights coming on every time you use hi-beam. If the vehicle is only for off roading then no probs.
    Buy a fuse holder (pre wired is easiest) and wire from Battery Positive via the fuse to PIn 30 of the relay (no need to fuse the signal wire from teh headlight)... Pins 87 and 87 A go to the lights.
    When hi beam is selected and the cabin switch is on then the relay will close and the lights will come on... dim the mains OR switch the switch and they will go off.
  8. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    Dark 1 (3rd April 2011), Finly Owner (2nd April 2011), the ferret (3rd April 2011)
  9. #6
    Jul 2010
    Waterford West Qld
    I wasn't sure I could put all that in writing without tripping myself little lone any one else. Thanks ET
    Tim
  10. #7
    Hiya Tim... no wuckers... your advice was good so no point in repeating it I just added a bit
    Didn't someone post up some really cool pics for the wiring of Spotties etc from "Traxide" or was that another forum ?
  11. #8
    This one; http://www.nissanpatrol.com.au/forum...otlight+wiring
    Tony
  12. #9
    Mar 2011
    NSW
    Cheers fella's, been absolute champions. Having connected HID's to my bike a few years ago (GSXR 750 K8) I felt reasonably comfortable purchasing and connecting these however noticing the amount of f#$% ups I could potentially make doing it wrong I think I'll go see a specialist on monday hehe
    Thanks for the elaborate answers, on to the next big "mod" HID's all round haha
    Last edited by YNOT; 3rd April 2011 at 06:13 AM. Reason: watch the language please
  13. #10
    Sep 2010
    on the coast W.A.
    Don't mind help'n Ted, but can we keep the F word out of it, kids, family and women are on here too, cheers, Rod.
  14. The Following User Says Thank You to the ferret For This Useful Post:
    YNOT (3rd April 2011)
