Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Rust protection compounds
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Hi all
    Have been doing a little experimenting by applying different products onto bare metal and seeing what happens when I leave them in the elements. I've disolved beeswax into turps to turn it into a liquid and applied that to a small section of steel, a small section I applied marine grease and the 3rd section is marine grease and the wax, both disolved into turps. When dried, the wax section and grease/wax mix are both touchable and not sticky.
    Has rained all week very heavily and this is how it looks at the moment.
    Where there is rust, nothing was applied. Will leave it out in the weather for a few months and see which one works best.
    Andy
    IMO and should be taken with a grain of salt.
  2. The Following 5 Users Say Thank You to Parksy For This Useful Post:
    AB (5th May 2015), Bloodyaussie (5th May 2015), Clunk (5th May 2015), gaddy (5th May 2015), threedogs (6th May 2015)
    Thomastown, Melbourne
    6 Post(s)
    Quote Originally Posted by Parksy View Post
    Hi all
    Andy
    Good stuff Andrew... will keep an eye on this.
    Sump oil works well.
    Jan 2013
    Nowra NSW
    5 Post(s)
    Sump oil does work. But doesn't last long.
    22 Post(s)
    After the test is done, can you paint it? Just with chassis black or something? And no cleaning? Please
    96 GQ coil/Cab
    08 G6eT
    Jan 2013
    Nowra NSW
    5 Post(s)
    Can do Ben. Any reason for it?
    I've found Lanotec works well not sure how long it lasts though.
    enviromentally friendly too, has a thousand uses,
    always have a can on hand.
    Could you use your mix with a spray bottle or is it brush on only
    Parksy (6th May 2015)
  10. #8
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Just having a stab in the dark, but im guessing Ben is asking about a rust inhibitor that can be painted. Say you wanted touch up your bull bar or rock sliders, something that will protect the steel but can have colour on it
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  11. The Following User Says Thank You to lhurley For This Useful Post:
  12. #9
    22 Post(s)
    Just for harder to reach places, like chassis rail or cross members, just for experimental sake
    96 GQ coil/Cab
    08 G6eT
  13. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  14. #10
    Jan 2013
    Nowra NSW
    5 Post(s)
    No dramas. This stuff can be sprayed in a spray bottle. It atomises very well. That was the whole reason I disolved the marine grease, to make it spray able. I picked the marine grease because it's designed to resist being washed away, as well as to stop corrosion.
  15. The Following User Says Thank You to Parksy For This Useful Post:
    threedogs (7th May 2015)
