Page 497 of 1057 FirstFirst ... 495496497498499 ... LastLast
Results 4,961 to 4,970 of 10565
  1. #4961
    Nov 2010
    Getting a life...
    38 Post(s)
    Quote Originally Posted by roofy View Post
    don't worry about pinstripeing adds character you and your show pony
    Na-ah... Shiny is pretty.
    Pretty is nice.
    Beasty will be pretty when it comes home.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  2. #4962
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Pretty is nice.
    Not for long mate
  3. The Following 3 Users Say Thank You to Sir Roofy For This Useful Post:
    cgm (29th April 2015), katwoman (28th April 2015), Stropp (28th April 2015)
  4. #4963
    Had a noisy bearing from the last mud bash. Hoping it was the a/c idler.... Nope its the a/c bearing itself. Put it all back together with less tension on that belt for now.
    Next will have to look at an exhaust leak somewhere in the engine bay.
  5. The Following User Says Thank You to jay see For This Useful Post:
    lucus30 (29th April 2015)
  6. #4964
    Nov 2010
    Getting a life...
    38 Post(s)
    Polished all my black bits.
    Nice, ay Man in the hat ?
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  7. The Following 2 Users Say Thank You to katwoman For This Useful Post:
    Clunk (1st May 2015), Stropp (1st May 2015)
  8. #4965
    TRAFALGAR VIC
    35 Post(s)
    Grrrrrrrrrrrrr
  9. The Following User Says Thank You to Sir Roofy For This Useful Post:
    katwoman (30th April 2015)
  10. #4966
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    When is the Lean Green Machine going to be ready Roofy
  11. #4967
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by Bob View Post
    not far away mate there just a bit slack
  12. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Bob (30th April 2015)
  13. #4968
    Wired up two Baintech volt gauges ,one for the main and the other for the AUX battery
    Main comes on with ignition, also starting to run yellow RCA cable to the rear.
    No idea where to fit the camera, Im thinking just above the towball, no rush
    never needed it before so it should be interesting.
    Plenty of space on the dash centre fascia for switches and gauges, would like to fit more.
    Still need to move the UHF to the passenger side, and move the Cruise control light
    up to the pillar pod, Plenty of 12v jobs left to do. Found some awesome leds to use
    for awning lights
  14. #4969
    Put the camera just above the number plate John. Under the black bezel with Patrol on it. If you have it too low you will lose perception of distance I think. Plus under there its hidden and makes it easy to line up the towball when hitching up.
  15. The Following User Says Thank You to mudski For This Useful Post:
    threedogs (1st May 2015)
  16. #4970
    yeah was thinking that but its a PITB getting the wires through the rubber sleeving on the small door.
    Never needed a reverse camera yet, with the camper you just line it up between the mirrors and slowly reverse.
    Might make life easier though as long as I can see the towball, thanks again Mark
