Results 11 to 20 of 31
Thread: Getting a drive train clunk when turning.
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    I've also had clunks when turning from worn body bushes( felt that under my feet) , loose nuts on aftermarket sway bar links ( chassis bracket) and those flexy coils with the thinner top coils ( coils bind and unbind and eventually snap)
    Few more things to check
  2. The Following User Says Thank You to liftlid For This Useful Post:
    mudnut (17th April 2015)
  3. #12
    Yeah the good old GQ body mounts have a habit of collapsing after a while. My middle ones are on the way out now.
    What about backlash? Give the tail shaft a twist back and forth see how much movement there is (in neutral no handbrake). . .
  4. The Following User Says Thank You to Rossco For This Useful Post:
  5. #13
    Quote Originally Posted by liftlid View Post
    Yep mine are a bit knackered too, got a few clunks coming from the front passengers footwell, only on wet roads.
    Body mounts are bloody expensive though!
  6. #14
    84 Post(s)
    There is 1 1/2 to 2mm of backlash at the diff when I twisted the tail shaft.
  7. #15
    Hmmm, doesn't sound too bad although I'm no means an expert. . .
    Yeah body mounts are bloody expensive, it's a fair job as well putting them in.
  8. The Following User Says Thank You to Rossco For This Useful Post:
  9. #16
    Is it any harder than installing or removing a body lift? I wish I had done mine when I took out the body lift.
  10. #17
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by winnie View Post
    yep mine are a bit knackered too, got a few clunks coming from the front passengers footwell, only on wet roads.
    re think that winnie d/c 4 didnt help thow that would have made a couple more clunks
  11. #18
    Quote Originally Posted by roofy View Post
    I've only driven the car once since that weekend, lol it did it before then too.
  12. The Following User Says Thank You to Winnie For This Useful Post:
    Sir Roofy (17th April 2015)
  13. #19
    TRAFALGAR VIC
    35 Post(s)
    i've only driven the car once since that weekend, lol it did it before then too.
    all i got was a massive clunk lol
  14. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Clunk (17th April 2015)
  15. #20
    Yeah and a bit harder to repair than body mounts!
