Results 1 to 10 of 12
Thread: RB30 Bad Cold Idle
Threaded View
  1. #6
    Advanced CaptainNewman's Avatar
    Jun 2013
    SA
    Cheers everyone for the help. Mudnut I found a few split vacuum hoses under the air cleaner box, replacing these has helped the problem a lot. Also mate your RB30 "Helpful Hints" page has been absolutely useful, I actually discovered it months and months ago, and refer to it all the time!
    TroutNut I checked the choke valve, it sometimes gets "stuck" open, so on a cold morning just need to blip the throttle before starting to reset the valve to the closed position. Sticky linkages ? !
    Dom14 its only on Petrol, and I'm going to look over the vacuum lines for brakes soon too.
    Cheers everyone again.
  2. The Following User Says Thank You to CaptainNewman For This Useful Post:
    mudnut (13th April 2015)
