Surely he can not have just got 3 faulty fans?
threedogs (8th April 2015)
Aaaahhhh, the plot thickens Dr Watson,
Curious as to why did you check the airflow with paper and your hand instead of just visually confirming the blade rotation?
I ask purely because airflows can be very deceptive around radiators etc.
Thinking about this again last night I was also wondering if cavitation may be an issue
At least being Davies Craig and only a few months or in the 3rd case, hours old, I'm sure they will make good on any faulty gear.
I wonder if setting the thermostat [for the fans] lower would help and what value thermostat is fitted[for the motor]
Getting curiouser and curiouser lol. I think they need a shroud to be more efficient, but need to source problem first
Fan working should hold a full sheet of paper to the front of the radiator easily
I have a brand new shroud here for a single 21" fan if you need it[alloy]
what size radiator??mm x mm
Surely Davies Craig will have an answer ,they must have come across this over the years
Qualified Auto-Electrician
Apprentice Sparky
Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
No worries, Cobber.
Not trying to tell anyone who has posted to suck eggs... this is for others reading the thread in future or DIY
If the fans are installed as pullers the installer also needs to swap the "polarity" of the motor leads not just reverse the blade assy and double check that the "must face forward" is correct as marked on the fan.
Davies Craig make very similar models that rotate clockwise and anti-clockwise and that is an easy trap to fall into as well (learnt that from experience insert forehead slap here)
http://www.daviescraig.com.au/Images...(08-08-06).pdf
NissanGQ4.2 (8th April 2015)
Are you sure its not overheating?
Does he only have the standard GU temp gauge or is he running an after market temp gauge?
How close is this particular part that is stripping to the core?
What else is in front of the radiator? Why did he do away with the viscous?
