Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Gq Brake bias
    cairns
    In my opinion the more tension on the spring the more braking to the rear . the spring in the photo looks tight . Is the arm coming off the adjustment screw as far as possible from the end re can not move any closer to the spring. if so then the rear brakes have full power which could be causing them to lock . Forget about the spring length and adjust the tension via the elongated hole in bracket connected to the diff try it in the middle of the adjusting pin do not turn pin as this is factory set. Is your vehicle loaded or unloaded if unloaded or light the arm may need to be closer to the end of the adjusting screw. When I did my ute I placed a jack under tow ball and lifted weight off the axle the spring depressed meaning less breaking needed as less weight when lowered the spring tightened meaning more weight which would require more rear braking just a thought .
    2012 gu6 dx canopy factory snorkel and bull bar new bfg all terrain, bellow style air bags, uhf, centre console, tinted windows, projecta 150 amp dual battery set up ipf super rally spotties, nitro oil shocks
  2. #22
    Have you sorted this out Jonathan? I want to upgrade to EFI front calipers and will rebuild them all when I find some. I think my front brakes are just not working very well
  3. #23
    cairns
    Hey Winnie it could be that your rear brakes are working too well . Try adjusting brake bias first as per my last post then you will feel more from your front brakes hopefully
  4. #24
    Quote Originally Posted by alfonso View Post
    I will have to re read that while looking at it, but thanks for that
