Results 1 to 6 of 6
Thread: question about vdo boost gauge.
    Apr 2013
    newcastle, nsw
    Hi guys/gals need a bit of insight on this one.
    I have a vdo boost gauge and installation was easy enough but are they meant to emit a leaking air noise that gets stronger with more boost or do i have to tighten the boost line fitting more?
    Thanks for any info/help.
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    I would suggest that it should not be sucking any air. Could be wrong though.
    Sent from my iPhone using Forum Runner
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
  3. The Following User Says Thank You to krbrooking For This Useful Post:
    Timbo15 (6th April 2015)
    If it has a brass olive you place on the tubing before the nut ,
    then you will need to nip it up so it squashes slightly
    177 Post(s)
    They also have a small nyon ‘restrictor’ to fit inside the tube - part no 10027 - see pic. Not sure if it would cause the issue you have if missing, but does apparently stop the needle from being too ‘jumpy’.
  7. The Following User Says Thank You to Cuppa For This Useful Post:
  8. #5
    Apr 2013
    newcastle, nsw
    Thanks guys for the help. Cuppa the nylon restrictor was the part I needed to install, only took a while to find where it was hiding.
  9. The Following 2 Users Say Thank You to Timbo15 For This Useful Post:
    Avo (6th April 2015), threedogs (6th April 2015)
  10. #6
    177 Post(s)
    So anyone wanna buy my VDO boost gauge as pictured above?
