Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Gutless GU 4.8????
    I'm thinking while down at Super Cheap get a Max ellery manual as it shows
    procedures on how the correct certain errors ,way tooo complicated to explain here
    From what Ive read on the 4.8 going they are great, but a bit finicky like the ZD30 in some respects
  2. The Following User Says Thank You to threedogs For This Useful Post:
    glennb (15th March 2015)
  3. #22
    Expert Bloggsy's Avatar
    Perth WA
    G'day, I'm no expert by a long shot but had a similar bunny hopping thing in my old GQ TB42 many years ago. Funnily enough in 3rd gear. Ended up being a faulty (but new) HT lead. So i am thinking maybe a faulty coil pack in your case? just something else to check. Good luck!
  4. The Following 2 Users Say Thank You to Bloggsy For This Useful Post:
    Clunk (16th March 2015), glennb (27th March 2015)
  5. #23
    Apr 2014
    A bit of an update for you all.
    Went to 2 differnt mechanics just for shits and giggles to see what the general opinion was. turns out according to there computers that there is nothing wrong.
    Everything checks out fine with no codes.
    i have done a bit more playing around and found that the problem is that the computer is not advancing the timing.
    its running ratarded as hell all the time. if i advance it by hand the thing goes like a rocket but ideles at about 1800 rpm.
    i know in most other cars that the MAP sensor tells the computer to advance the timing and i know that these thigs use the TPS as a MAP sensor so im going down that road first. Then followed by air flow metre.
    Wish me luck..... im goin in!!!
  6. The Following 2 Users Say Thank You to glennb For This Useful Post:
    BigRAWesty (27th March 2015), Clunk (27th March 2015)
  7. #24
    Apr 2014
    Update V2.0
    Have found the problem. timing chain is totally shot and out by 2 teeth. Hence the timing being so far retarded.
    looks like i have to go genuine for a new kit though so thats gonna be one scarey phone call that ill be making tomorrow.
    now praying to the nissan gods that the valves aren't bent.
  8. #25
    Perth WA
    Glad you've found the issue. Maybe try a few of the vendors on here like NIZZBITS (Garry), Mudski etc... For a price.
  9. The Following User Says Thank You to Bloggsy For This Useful Post:
    glennb (1st April 2015)
  10. #26
    And patrolapart and adoc (i think)
  11. The Following User Says Thank You to Clunk For This Useful Post:
  12. #27
    Apr 2014
    Thanks guys.
    Ive ale
    ready contacted patrolapart via there contact us link so hope to hear back from them tomorrow.
    It didnt come up with any results on the search.
    gonna send Nizzbits a msg now.
  13. The Following User Says Thank You to glennb For This Useful Post:
    rusty_nail (2nd April 2015)
  14. #28
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    sounds to me like someone was playing around
    or
    had to replace the timing chain - at home - with no idea on what they were / are doing
    do yourself a favour, and get a manual with pictures and some wooden wedges
    when you take the cover off - BEFORE doing anything, have a look at the timing gear........ make sure the marks line up where they are supposed to
    if they are ok, you will be safe to hand wind the motor over until you find the joining link in the chain
    join your new chain onto the old one, and hand wind the motor over until you are back at the joining link
    remove old chain, join both ends of the new chain
    put it back together
    THEN
    take plug 1 out
    scrunch up a piece of t6issue, and put it in to plug 1 hole
    hand wind motor until tissue pops out - your now at Top Dead Centre
    check that all the plug leads are in the right order......... you would be surprised at how many get that wrong
    NOW check your timing
    and
    away you go...................
  15. The Following User Says Thank You to Bigcol For This Useful Post:
  16. #29
    Expert SpecialDave's Avatar
    Apr 2015
    Greensborough / sunshine / Aspendale. Kind of homeless at the mo
    So my 4.8 02 auto dual fuel was giving my mate (the dealer) an absolute nightmare of a time before It was ready - First of all, someone had tried a diy timing repair and it was trash. one we sorted that, i got the whole head redone whilst it was off for a burnt valve (probably because the timing was bonkers), it ran like a dream.... Then suddely and engine light, no code on 3 different testers and it would drop revs at stop and stall not idle... it would run if you kept the revs up and when driving no drama but slowing / stopping it died....
    After 3 days with an elec, 3 days with a transmission specialist it was finally decided my instrument cluster was buggered somehow, so that got replaced and bam, no worries. funnily enough my wife's old still running 99 pulsar had an instrument cluster known fault, tehre seems to have been a patch late 90's early 2000 where Nissan clusters were a bit on the temperamental side...
    02 GU3 Dual Fl Y61 4.8 Auto. 3"OME, Snorkel, roof tray, Dual Batt, CB, d8r winch, ledlightco bar, fact steel BB, Elec Tow. hid spots, rvrs & tow cams, rear door rattle fix, saas dual volt gauge, mostly fin cust dash pod, ludicrous work lights. TO DO: convert headlights - led? rear tails, full overhaul trannie & engine. rear storage. door table. O/h interior storage, Paint Matt black. Bash guards. Side rails. Roof ladder. Awning.
