2006 4.2TDi ex-Telstra Remote area Camper. Patrol Sold after 11 years of ownership Replaced with 2006 OKA NT Expedition Truck. Cummins, Allison & lots of goodies
Kempy (1st April 2015)
well, after reading TimE write up.........
bugga me, I dont have to worry about it
mine was a NA and I added the Turbo & intercooler from a 2006
so the butterfly is already disconnected and I dont have the EGR to blank off either
mine is wholey and solely NON computerized, so they were never connected up
cheers anyway Cuppa
Bit of a thread dig...
Will be doing the entire removal this weekend. Well, whats left of my EGR system, which is basically the heat exchanger, associated coolant lines and the pipe at the back.
I have found this kit at Patrolapart. (pic below)
Everything is very straight forward. Only one thing I'm confused about.
The coolant T piece at top of motor, is removed and a in-line pipe is inserted. (pictured below)
But...
What happens to the coolant barb on the block ?? How is it blanked off? It does not appear to be in the kit.
@nissannewby
I think its a threaded port into the block. You would remove the fitting and put a blanking plug in there. As for the size. I am not sure. I can have a look on the Nissanfast parts program tonight to see if it tells me anything.
Hodge (14th December 2018)
mudski (14th December 2018)
what this have to do with anything
