Page 490 of 1057 FirstFirst ... 488489490491492 ... LastLast
Results 4,891 to 4,900 of 10565
  1. #4891
    Patrol God Stropp's Avatar
    37 Post(s)
    ok got the patrol back, drives like a dream now and no more pulling to the left when on a flat road, the suspension guy did say easy cheap fix is a rtc steering damper if i didnt want to spend the coin but i told them to go ahead and do the offset swivel hub bearings, much better now.
  2. The Following User Says Thank You to Stropp For This Useful Post:
    Majestic (28th March 2015)
  3. #4892
    37 Post(s)
    Thats not very true.
    The nissan engineers designed the front suspension to a specific ride height and amount of travel. There was no regard for the consumer to install suspension lifts, get more articulation, different offset rims etc. It was designed with small tolerances, which really isnt good, but for standard form it functions as it should and quite well.
    Suspension is about comprimise. A change in geometry (ie lift kit) can effect other characteristics. In a setup like the patrol with its low margin of error design Something like a basic 2 inch lift can upset things. This is why there are what seems to be many causes for the death wobbles.
    but it seems you dont have to have a lift kit to get the wobbles either but it will be more likely to get them with the lift kit
  4. The Following User Says Thank You to Stropp For This Useful Post:
  5. #4893
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Latest mod..
  6. The Following 2 Users Say Thank You to mullet_hunter For This Useful Post:
    Clunk (27th March 2015), threedogs (28th March 2015)
  7. #4894
    Quote Originally Posted by mullet_hunter View Post
    Latest mod..
    And also one of the best mods
  8. The Following User Says Thank You to Clunk For This Useful Post:
    mullet_hunter (30th March 2015)
  9. #4895
    Western suburbs of Melbourne
    11 Post(s)
    Latest mod..
    Now your making 7 more horses. Lol
  10. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
  11. #4896
    Jul 2012
    N/a
    Put in a volt meter to keep an eye on the aux battery and spent most of the day replacing the actuator and fine tuning the dawes and needle valves after the change.
  12. The Following User Says Thank You to Dinger For This Useful Post:
  13. #4897
    Latest mod..
    You've come a long way fast Pilgrim,,lol
  14. The Following User Says Thank You to threedogs For This Useful Post:
  15. #4898
    Unafordable
    4 Post(s)
    Decided to change all brake pads before Easter Southern Flinders trip.
    Interestingly, I found that these Bendix aftermarket pads contain less friction material compared to genuine Nissan pads.
    Genuine pads front 12 mm aftermarket 9-10 mm, rear 10 mm aftermarket 8 mm.
    Makes me wonder what is going on.
    Well time will tell if it was the good decision to go with these fancy Bendix hybrid pads. They certainly have less "meat" on them than genuine Nissan ones.
  16. The Following User Says Thank You to Rumcajs For This Useful Post:
    Dinger (28th March 2015)
  17. #4899
    Packing the beast for a week on the Murray!
  18. The Following User Says Thank You to AB For This Useful Post:
    Stropp (28th March 2015)
  19. #4900
    37 Post(s)
    Yes I'm getting ready to head off Wednesday for Cheyennes beach near Albany for Easter weekend.
  20. The Following User Says Thank You to Stropp For This Useful Post:
    AB (28th March 2015)
