Page 489 of 1057 FirstFirst ... 487488489490491 ... LastLast
Results 4,881 to 4,890 of 10561
  1. #4881
    Nov 2010
    Getting a life...
    38 Post(s)
    Ran LEDs in the new drawers, filled drawers with 2 ton of crap, fixed window switch that hasn't worked in two years, looked at the new springs. Much heavier.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  2. #4882
    Is the ute going to be ready for the weekend, Kat?
  3. #4883
    Nov 2010
    Getting a life...
    38 Post(s)
    No. Afraid not. It's only just ready for paint. It'll have to wait till the next one.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  4. #4884
    Bummer! Oh well
  5. The Following User Says Thank You to Winnie For This Useful Post:
    katwoman (25th March 2015)
  6. #4885
    snip...
    I am keen to see the outcome of this. The dude at Pro Axle showed me the adjustable top swivel hub bearing plate they sell, so you can adjust the camber of the wheel. It was around $280 fitted and adjusted from memory, but he said to me this wouldn't change the pulling left issue, it only straightens the wheel so you have even wear across the tyre. Not just wearing more on one edge of the tyre.
    I took it that he is correct, but he may be incorrect, I'm only repeating what I was told...My head hurts now....
    Sounds like a very knowledgeable man.
    Many, many moons ago in my boy racer heyday it was often uneven Castor angles between the LH and RH suspension that caused a vehicle to pull one way or the other.
    Toe in is used to stop twitchy steering over bumps or a vehicle trying to dart in to a corner
    Incorrect toe should wear feathers across from the inside or outside edges of the tread
    Camber is used to set up the correct angle of the tyre to the surface as the tyre deflects under cornering forces and should do sweet FA in a straight line if all else is OK (look at a V8 supercar for example)
    Incorrect camber should wear evenly around the circumference of a tyre but more heavily from one side to the other across the tyre
  7. The Following User Says Thank You to the evil twin For This Useful Post:
    mudski (25th March 2015)
  8. #4886
    Expert Agronaught's Avatar
    Sydney, NSW
    Suspension work done, and the car is sitting level again, yay! The rear springs were really bad and simply didn't cope with the addition of all the gear I've added to the car. Driving home it was a completely different beast.
    I've opted for medium duty springs to cater for the camper and losing up the car. As a result the rear of the car is riding a little higher... I like it .
    I can't wait to get it on the tracks
  9. The Following 2 Users Say Thank You to Agronaught For This Useful Post:
    cgm (25th March 2015), Stropp (26th March 2015)
  10. #4887
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Quote Originally Posted by Agronaught View Post
    It is a nice feeling when it all comes together like that. Good stuff.
    Thanks, Cameron
    No Patrol now - Just good memories!
  11. #4888
    Sydney, NSW
    Quote Originally Posted by cgm View Post
    I'm happy. Yes I spent more than was necessary, but at the moment I'm time poor and would really prefer spending the time I have on a track somewhere. There's also the case that the only place I talked to that had all the right answers this time was ARB.
    This was a case of time verses money... Time won.
    The young woman I talked to at TJM may have known what she was talking about, but I didn't get that feeling after our chat. It sounded like I was being given the same spiel they gave on the web site with no added information. The quoted price was no different so it's academic anyway.
    The only alternative I would have had was to buy the kit and do it myself, or find an independent specialist to do the work. A little difficult to find where I live as it turns out.
    J
  12. The Following User Says Thank You to Agronaught For This Useful Post:
    cgm (26th March 2015)
  13. #4889
    Got my snorkel fitted.
    Thanks Threedogs.
  14. The Following User Says Thank You to jay see For This Useful Post:
  15. #4890
    22 Post(s)
    yes swivel hub bearings, spoke to my mechanic and he said nissan were never too fussed with setting up the suspension correctly and thats why we get wobbles etc and says it will definitely help so she will be full steam ahead,
    I was under the assumption that Nissan "over engineered" the Patrols. Hence the tough driveline we have. I would have though the suspension would be the same?.
    Thats not very true.
    The nissan engineers designed the front suspension to a specific ride height and amount of travel. There was no regard for the consumer to install suspension lifts, get more articulation, different offset rims etc. It was designed with small tolerances, which really isnt good, but for standard form it functions as it should and quite well.
    Suspension is about comprimise. A change in geometry (ie lift kit) can effect other characteristics. In a setup like the patrol with its low margin of error design Something like a basic 2 inch lift can upset things. This is why there are what seems to be many causes for the death wobbles.
    96 GQ coil/Cab
    08 G6eT
  16. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    MEGOMONSTER (26th March 2015), mudski (26th March 2015)
