Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Working Tail Light Install
    LEDs produce no heat as there is no working part so to speak. I have 2 x 120 smd LEDs in each side
    reversing in the bush is now doable, I have since removed to 27watt flood light, as Ive plenty of light.
    so 480 smd leds in all , in fact my Patrol is completely LED and HID
    They actually do produce heat, but not as much as an incandescent would. Otherwise my light bar would have cooling fins on the back of it. And my LED downlights too.
  2. #12
    Your both right... sort of... LED's don't produce heat but the electronics to drive them does (sometimes a little sometimes a lot) and they are normally co-located.
  3. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    mudski (24th March 2015), threedogs (25th March 2015)
  4. #13
    Yes I was going to edit that to my OP but got the CBF's. Lol.
  5. #14
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Thought I'd add to the rear light portfolio.
    This set from Patro lA Part. easy install and effective. Brake lights work as well but couldn' make my foot reach that far from the camera.
  6. #15
    Not a lot of heat either, I'd call it warmth. Lol. A lot of the cheaper ones can actually get to what I would call, very warm, though.
    Incandescent lights are approximately 10% light, 90% heat, and the filaments burn at over 2000 degress celsius.
  7. #16
    Expert Malgreen's Avatar
    Yulara
    hi guys...
    time for some advice please..
    i have a 08 crd patrol and i got the working rear lights off from Ebay..
    ok , but the problem i got is in the wiring... i cant find the factory loom that i keep hearing about,,
    so, will i have to splice off from the lights in the bumper or from the towbar? will the existing wiring be able to handle the bumper lights and the towbar and the extra lights that i will add? i am also thinking of another set of lights on the roof rack.
    but i am worried about the load on existing wiring.
    i was thinking of running a new power line down to the back and run relays off from the positive wires for each set of lights.. ie relay for brake, parkers, indicators and reverse.
    that would mean that the active wire ,for say, the brakes would activate the relay to turn on brake lights in the new lights...
    if i did this, would the indicators blink at a different rate?,,
    or
    i just wire directly from the towbar wiring and replace all globes with led? less draw and less stress on the wiring ( and me,, lol )
    cheers
  8. #17
    Aug 2014
    Kingsley WA
    15 Post(s)
    The set I got from Patrol a part had led brake and tail lights, so no real increase in load. Factory loom should be plugged into the passenger side tail lights which are usually wired in. You may need to pick up drivers side indicator from the bumper bar.
    IMO the existing wiring should handle it OK or there would be problems every time someone hooked up a caravan or whatever. The turn indicators would probably flash at a slightly different rate but should be ok. If you are going to put lights on the roof rack, I would suggest that you put a plug and socket in so the RR can be removed from the vehicle if you want. I even have my RR spots, I mean work lights on a plug and socket system.
  9. The Following User Says Thank You to 4bye4 For This Useful Post:
    Malgreen (25th April 2015)
  10. #18
    Expert Ibbo's Avatar
    Mt Barker, SA
    Can you buy just the loom, globe holders and globes to fit into the existing blank rear body lights in the GU? I have had a look on ebay and patrolapart but can only find them as a package with lenses
    Sent from my LG-D295 using Tapatalk
    2010 GU, 2in lift, old man emu suspension, duellers, arb bullbar, dual batteries, safari snorkel, scangauge2, rhino rack platform, saving for more......
