Page 208 of 262 FirstFirst ... 206207208209210 ... LastLast
Results 2,071 to 2,080 of 2619
Thread: The Knife Thread
  1. #2071
    Patrol Freak Gecko17's Avatar
    Mar 2013
    Quote Originally Posted by oncedisturbed View Post
    Cheeky farker lolol, its ok cuz wifey blames you for telling me about the collectors zone at clarkson....bwahahahahahhahahahahahahahahahahahaha hahahahahahahahaha
    BTW it is a gooood knife, payback for the tanto chopper you got recently.....muah
    We would be able to come up with some sweet gear when you get the CNC machine.
    Let us know when you get back so I can knock up the templates for you to make up the sheath vice presses, will be able to knock out some good wet moulded sheathes then
    Just wait 'til you see that freakin Tanto! It is a beast...
    Not sure when I am gonna be home. Have just been asked if I can stay until the end of March but don't think the project will last that long so will see. At least I should be home for Easter. Unless I get another job that wants me to start asap....Meh, what's 3 months away from home....
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
  2. The Following User Says Thank You to Gecko17 For This Useful Post:
    threedogs (5th March 2015)
  3. #2072
    http://www.ebay.com.au/itm/Mtech-Mil...-/291399256142
    Time to start looking again, this might match the mighty "bumble bee" I have from M-tech
    oncedisturbed (9th March 2015)
  5. #2073
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    I quite like it, I have a knife with the same handle scales and is comfy which was a surprise. Nice shape blade for general work and sheath looks alright as well
    www.swat4x4.com
  6. #2074
    was just looking at some of the Colubia and San-Jia knives but I cant bring myself to push the button
    because of those crap nylon sheaths they come with, really lets a knife down IMO
  7. #2075
    OK here is the Deal! just getting into Hunting, was at a Gun show on the weekend and looking at Knives for the first time really. I am looking for 1 knife only. Bet knife for hunting. Interested in your recommendations guys. Rabbits through to Deer.
    Links would be appreciated too. I am advised to find a short blade round with the best edge possible. Keen.
  8. #2076
    any clip point,,,, pictured are a knife Ron moon has and the other is one Janderson has
    both Schrade blades are 5" long each
    For a folder you cant go past a BUCK 110 3.75 " blade
  9. #2077
    Feb 2012
    30 Post(s)
    Are you looking for a general purpose knife or 1 just for skinning?
    Have you already been given some ideas from the show at all or have your eye on any in particular?
    www.swat4x4.com
  10. #2078
    I'll put pics if you see something you like all the better.
    Did you run into Simon and his Kysler contacts
  11. #2079
    Yeah i thought i wanted the ones in the right pic John but clearly from the discussions i had with a number of Knife guys at the show i am now looking at the ones in the Left pic.
    No i have not spoken to Simon, he has a bit on his plate at the moment.
  12. #2080
    Feb 2012
    30 Post(s)
    It will come down to personal choice and what you feel comfortable holding / using.
    If you are leaning towards 1 of the 1's in the left pic, personally I would choice either bottom left (brass bolsters, easy to clean and maintain) or in the same pic the 3rd on the right, the Browning upswept skinner (I have 1 of these also and super sharp and great little knife).
    Some gut hooks are a right pain in the butt to use as generally they aren't shaped properly such as angles and size, making it harder to use hence the suggestions made.
    Same as TD and Gecko, I have several knives that I can choose from depending on what's needed at the time, smaller knives for small game and then bigger versions for larger game.
    I tried to use a small upswept skinner doing a roo a few times, whilst it did it's job, it took a lot longer to dress and ended up changing to a larger knife to finish it off so I usually have 2-3 knives in my shooting bag and sometimes a larger knife on the belt as well.
    www.swat4x4.com
  13. The Following 2 Users Say Thank You to oncedisturbed For This Useful Post:
    Alitis007 (25th March 2015), MudRunnerTD (24th March 2015)
