Page 484 of 1057 FirstFirst ... 482483484485486 ... LastLast
Results 4,831 to 4,840 of 10566
  1. #4831
    I swear I read somewhere Eric that you had an ARE scoop on. I swear I seen it on too... I gotta stay off the funny stuff.
    Hodge (19th March 2015)
  3. #4832
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    One of the headlight globes called it quits so decided to upgrade to one of the Narva Arctic ones.
    Found out what a major PITA changing gloves is, especially on passenger side. Much much easier to remove the headlight assembly.
    Saves a lot of skin, blood, nerves and swear words...
    2 beers later, job done .
    Good results.
    I did the same. What a turd obviously designed for tiny handed men
    Lucus30's 1999 GU ST TB45E
  4. The Following User Says Thank You to lucus30 For This Useful Post:
  5. #4833
    Sep 2013
    16 Post(s)
    When we buy a house that is going to be a prerequisite... Lol
    Hindsight is a wonderful thing. I didn't have my patrol when I bought my house. I've said to the wife when we build a new garage I'm making it freaking huge and tall
  6. The Following User Says Thank You to lucus30 For This Useful Post:
    TroutNut (21st March 2015)
  7. #4834
    I had mine. But still the house won over the shed size.
    Nov 2010
    Getting a life...
    38 Post(s)
    Good results.
    I wanted to do this job while the bullbar was off recently, but didnt have the gear to do it, so Ill be doing it that way too.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  9. The Following User Says Thank You to katwoman For This Useful Post:
  10. #4836
    177 Post(s)
    Nope never had one fitted. I pre-ordered one, but at that time it was gonna take forever to come in. So i gave up...
    Yeah, to same some skins, it really is super quick. 3 bolts each side, with a 10mm socket and it's out. And that way you can see exactly how you're slotting in the globe and how that spring clamp works.
  11. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    katwoman (19th March 2015), mudski (19th March 2015)
  12. #4837
    Expert Majestic's Avatar
    Oct 2014
    Central West NSW
    Got a new lightbar today, however I can't figure out why it isn't work. I suspect that it has to do with the previous owners wiring in the cabin end, the rest I did myself and triple checked. I pulled out his wiring from the bonnet end and it pissed out water, pretty bad smell to it as well. That is clearly not good, good thing I am doing it.
    Going to the brother-in-laws tomorrow so might ask him or his brother if they can suss it out for me. I'm a boilermaker by trade not a elecko and not very good with electronics. lol
    Good results.
    GQ's are the same. I recently upgraded my globes and in the end the passenger side headlamp was removed. Just no room behind it to get ya hand in behind it. Damn pre-cleaner is in the way. lol
    Owner of 1984 SD33T MK Patrol
    Owner of 1989 TD42 GQ Patrol
    Previous Owner of a 1988 TB42 DA Maverick
  13. #4838
    Put an extra earth lead from the chassis to the body yesterday as apparently these earthing on these cars arent the best.
    Now my air bag light flashes! Ugh!
  14. #4839
    Disconnect battery for 34 minutes??
  15. #4840
    Mar 2015
    ACT
    Well not today, but a week ago I put a carbi kit through after the dissy played up, as I though I had a tank of bad lpg as it misfired and backfired after leaving the servo near Bundanoon/Exeter. Played with the float again, solved most of my problems with a can of carbi cleaner and found that the float drop setting is just as important as its height(full) setting. Now it fills and stops on the sight glass dot, although the fuel return solenoid is stuck permanently in the full open position, which I assume will mean I lose some of my fuel bowl filling pressure at higher engine speed.
    After rekitting the carb, I found a small rubber plug on the driveway, yesterday. The Gregorys manual shows a pic of it, it goes next to the accel plunger, manual says ball, spring, weight, PLUG. Dammit, I looked at the thing for a while and it didn't seem entirely unfamiliar to me. I pulled the carbi apart a few years ago with the same dramas, after neglecting to use the petrol system for too long, and recalled a small plug between the top cover and the main carbi body. The carbi still started on petrol without it, but stalled like it had been on lpg, which turned out to be the ignition module in the rb30 dissy playing silly buggers with me. One minute I had spark, next I didn't.
    So, about today. I have to put the rubber plug back in. I hate finding left over bits. At least I hadn't driven around on the petrol and thought I had more issues, as the lpg is running without this tiny bung in place.
    I could have saved a lot of time, and diagnosed the dissy problem straight away, if I had kept the petrol side up to scratch.
