Page 37 of 50 FirstFirst ... 3536373839 ... LastLast
Results 361 to 370 of 498
Thread: Outback Ideas Recovery points
  1. #361
    Expert SG1's Avatar
    Sep 2014
    Gippsland, Vic
    Thanks, recovery points sent Monday arrived first thing Tuesday, excellent quality and very happy, will put some pics up in my vehicle thread soon.
    02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
  2. The Following 2 Users Say Thank You to SG1 For This Useful Post:
    BigRAWesty (3rd February 2015), threedogs (3rd February 2015)
  3. #362
    PM sent hope it works
  4. #363
    For those waiting I should have them back from the sheet metal guy next week
    rkinsey (13th March 2015)
  6. #364
    Patrol Guru Rocket55's Avatar
    Sydney
    John, I've got a 2005 TD42tI which has the lower radiator guard and an ARB Bullbar which mounts as per the pics above.
    The folded points won't fit due to the radiator guard.
    The "T" points won't fit due the the folded leading edge of the bullbar.
    Do you have any other options?
    I do have a spare standard front Nissan hook from another vehicle I will mount on the passenger side in the mean time, at least I can spread the load across 2 points, but would like something more substantial in there long term.
    Cheers Rod
    My Build 2005 TD42TI
  7. #365
    Is that one of my flat plates on the inside of the chassis,
    You have now become the third person with this combo Ive come across.
    Im going to the laser cutters next week I do have one but it needs some finessing
    I might get him to cut some out of MDF and post them to you for a trial fit and see how we go from there.
    What I would probably do is if it was mine is install the tee shaped ones , buy cutting that flange off
    and welding the TEE plate to it. plenty of ways none easy
    from memory that lip is 30mm yes???
  8. #366
    Sydney
    That's not actually my car, so I don't know what that red plate is in the background, but it's exactly how my Bullbar mounts up. Yes the front leading edge is around 30mm wide.
    I'd prefer to avoid welding stuff if I can.
    Happy for you to send out some MDF ones for a trial fit.
    Cheers Rod
  9. #367
    do you have 3 vacant captive nuts on the inside of the drivers side chassis.
    Passenger side will only have the holes
  10. #368
    Sydney
    Yes that's correct. Drivers side there is 3 captive nuts in a triangle configuration, 2 at the bottom, 1 at the top. The passenger side, these are just empty holes.
    You would need to remove the fan shroud to get a bolt into the rear most bolt hole and it looks like a radiator out job to access the other 2 bolts.
  11. #369
    I have the same setup John. ARB Delux bar and long radiator. Would likely now be a very common setup.
  12. #370
    LHS is remove the bullbar ,I think Mudski did a DYI thread about opening up the end of the chassis.
    My GQ plate fits the RHS of most models and years, but only as asingle
