Page 524 of 1465 FirstFirst ... 522523524525526 ... LastLast
Results 5,231 to 5,240 of 14641
  1. #5231
    Never been to Mansfield... And for this reason probably never will!
    I honestly can't remember a time I didn't go through Mansfield without the Main Street check on a long weekend.
  2. #5232
    You can take the corolla.
    Actually going through Mansfield on the weekend up to mt buller. . . It will be in the work ute tho. . . Hopefully old mate doesn't try and book us. . .
  3. #5233
    And if he does... Who cares! Hahaha
  4. #5234
    Yeah, not me! Good luck to him... I'll keep an eye out for the grumpy old bastard.
  5. #5235
    476 Post(s)
    I'd give Mansfield a wide berth mudski, cut in from Jameson way if your heading up to the hills. Heaps further but should avoid grief and a nice drive. Unfortunately, there's something about Mansfield. . .
    Yep. The Eildon-Jamieson Rd I'll be taking.
    Its a shame though, as its a nice place.
    Rossco (12th March 2015)
  7. #5236
    Fark fark fark............. something's not right at all with the old clunkers cooling system. Been using it to go back and forth to work in this week. So on Monday morning started her up and at first didn't seem to be firing on all cylinders, couple of dabs on the accelerator and was good. On the way temp rose to about 3/4 on the old reliable stock gauge. So before driving home Monday night, checked coolant level and ended up having to top up with a litre of coolant, overflow bottle level was on minimum. So kept the radiator cap off, started her up and again not firing on all cylinders at first, then came good. Lots of bubbles from the radiator filler too for a few minutes but came good, so I thought ok, probably had a bit of air in the system. Temp gauge sat under half way on the drive home, which is where it normally sits.
    Tuesday morning start the car, once again seemed like it wasn't firing on all cylinders at first but came good quickly and temps stayed normal to and from work. Same thing this morning and leaving work but only about 1km from home, temp gauge rose and rose very quickly to just past 3/4, so turned the heater on fully hot and nursed home. Still to hot to check how much coolant has been lost but there's not much in the in the overflow............ So I'm fearing the worst and right now it could not have come at a worse time, what with trying to sell the fecking thing and the boys hospital visit next week. To say I'm mightily pissed off right now would be an understatement.
  8. #5237
    476 Post(s)
    Thats no good mate. I doesn't sound like its going to be something easy to fix too. Maybe a head gasket??? If so try some Silver seal in it, if your getting rid of it. Or until at least you can fix it properly.
    Clunk (12th March 2015)
  10. #5238
    Chin up buddy.
    Hope it's nothing too bad.
  11. The Following User Says Thank You to jay see For This Useful Post:
    Clunk (11th March 2015)
  12. #5239
    Yeah can't just do a quick fix, would way heavily on my conscience. I need it sold so it needs to be done properly.
  13. The Following 3 Users Say Thank You to Clunk For This Useful Post:
    jack (11th March 2015), mudski (12th March 2015), TPC (11th March 2015)
  14. #5240
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Doesn't sound good clunk. Hope there is a way forward that isn't too bad.
    Thanks, Cameron
    No Patrol now - Just good memories!
  15. The Following User Says Thank You to cgm For This Useful Post:
