Page 478 of 1057 FirstFirst ... 476477478479480 ... LastLast
Results 4,771 to 4,780 of 10565
  1. #4771
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Flexed it up on some tyres cause I can.
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  2. #4772
    Quote Originally Posted by Punderhead View Post
    are you putting small side windows in or leaving it as it is ?
  3. #4773
    Nov 2011
    Toowoomba, QLD
    Haven't decided. Definitely putting in a rear window, but will have to see what looks good for the sides. Will probably leave as is though, as I don't mind the look.
  4. #4774
    Nov 2011
    Toowoomba, QLD
    Just put the rear diff in the shorty. Has a slammed ricer look now! Also have a time lapse video which I will put in my build thread.
    Cheers.
  5. The Following User Says Thank You to Punderhead For This Useful Post:
    Stropp (9th March 2015)
  6. #4775
    476 Post(s)
    Finished the longe range sub tank install. Chucked 30ltrs in it and the sub tank light in constantly on and I cant operate the pump. Ugh!
    I've just disconnected the battery to see if this helps but I have a feeling I need to bleed fuel into the pump maybe to get it started.
    I also readjusted the rear sway bat links and changed the oil. ..
  7. #4776
    Patrol God Stropp's Avatar
    38 Post(s)
    i think its just the reset required mate, happens quite often from what i believe. here's hoping
  8. The Following User Says Thank You to Stropp For This Useful Post:
    mudski (9th March 2015)
  9. #4777
    476 Post(s)
    I hope your right.
  10. #4778
    476 Post(s)
    I hope your right.
    Yep your right!
    Stropp (10th March 2015)
  12. #4779
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Had 2 sets of key replacement buttons delivered today. Just swap 1 set over, super sensitive now but cant complain for $10 a set
    www.swat4x4.com
  13. #4780
    476 Post(s)
    Quote Originally Posted by oncedisturbed View Post
    I take it the later Patrols have the buttons and key in one thing?
