Results 11 to 20 of 21
Thread: After market exhausts and catalytic converters
    Just for RW purposes I'd think most keep their Patrol as legal as possible.
    free flowing cat is nearly straight through anyway, eh
  2. #12
    Mar 2013
    NE Melbourne
    I suspect you are right. Who knows if they really do anything. They make the car legal though which is important.
  3. The Following User Says Thank You to Rock Trol For This Useful Post:
    threedogs (21st February 2015)
  4. #13
    How's the serenity boots's Avatar
    Sep 2011
    Before I replaced my original exhaust I gutted the cat and I have a pyro gauge fitted , 4B was more responsive and on average 50 to 70 degrees cooler across the board , one downside was the exhaust fumes were much more noticeable on a still or cold day . I have no regrets buying a beaudesert 2 3/4 inch system with cat . A great product .
  5. The Following User Says Thank You to boots For This Useful Post:
    Rock Trol (21st February 2015)
  6. #14
    Mar 2013
    NE Melbourne
    My original cat had also started to disintegrate so it was gutted about 18 months ago. I did not have an EGT gauge but the car ran cooler (digital water temp via scangauge) and it was more responsive down low. Torque started coming on tap about 200rpm lower than before. Also had the middle muffler replaced with a hot dog. Was happy with it and looked standard. Boots, you are right about the exhaust fumes from the motor. Did notice that originally. Now with the new cat I will take note. Hopefully cleaner and healthier.
    I only upgraded to 3 inch because I had the ECU remapped so went with a bigger exhaust. Car runs even cooler than before under normal driving conditions. I only had the EGT gauge fitted 3 days ago so have not had a chance to tow yet. For the last couple of months I have been a little hesitant in pushing the motor as I was not sure how hot it would get.
  7. #15
    Quote Originally Posted by Rock Trol View Post
    So what are your EGTs?? very interested
  8. #16
    Mar 2013
    NE Melbourne
    Around town the EGT temp sits between 220-300 degrees. After I picked the car up last Wednesday I took it for a drive north of Adelaide on the highway and if I pushed it (under acceleration) I could get it up around 400 degrees for a short time but once the speed was kept steady (100kph) it would drop to around the 350 degree mark. This was with aircon on and a warm day (30+).
    Not had a chance to go up a big hill yet or tow. That will happen in the next week or two.
    The EGt pyrometer is fitted just after the turbo in the dump pipe.
  9. The Following User Says Thank You to Rock Trol For This Useful Post:
  10. #17
    your's is a manual yes,
    You can see my bung for the pyro just behind the turbo.
  11. #18
    Mar 2013
    NE Melbourne
    Yes a 5 speed manual.
    I also let the car idle under the carport for a while and the exhaust smell was not as noticeable as before so it looks like the cat is definitely doing something.
  12. #19
    The smell is Nitrogen Oxides.
    NOX is a large contributing factor in the haze over cities.
    When you have a Cat fitted to the exhaust the Oxides are significantly reduced by the catalyst (Palladium) converting them back to Nitrogen and Oxygen and the 'exhaust smell' a lot less noticeable.
  13. #20
    Nov 2012
    You'd be hard pressed to find a good fitter that wouldn't fit one as their fines are huge, unless the vehicle is purely off road only.
  14. The Following User Says Thank You to Chad For This Useful Post:
    threedogs (9th March 2015)
