Page 97 of 570 FirstFirst ... 9596979899 ... LastLast
Results 961 to 970 of 5693
  1. #961
    Out of interest you can only place these in certain places
    is that right, does it restrict where you place it.
    Just thinking hot exhaust will cause it to fail, where do you place it ??
    under a side step and lift whole side of 4x4 up, ok in flat terrain.
    Everyone swears by them , I'm with the jury and out on this one
  2. #962
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    They come with a sheet to put on the top and bottom
    Lucus30's 1999 GU ST TB45E
  3. The Following User Says Thank You to lucus30 For This Useful Post:
    threedogs (27th February 2015)
  4. #963
    I put mine anywhere except directly on a hot exhaust... the pressure is spread over such a wide area it just moulds itself to the shape sorta.
    Same principle as airing down
  6. #964
    Oct 2010
    Old Bar, NSW
    Thanks guys, I think a mate has one. Might have a look at it and try lifting our cars before buying one for ourselves.
    Macca
  7. #965
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    This!!!!!!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  8. #966
    Quote Originally Posted by Punderhead View Post
    This!!!!!!
    Beast!.......
  9. #967
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Curious how you rate these. Going desert next year and want to leave the HiLift at home to reduce wieght. One of these could be a great substitute.
    Was planning to test it out today, but didn't quite get to it. On my truck the sliders are really flat and I reckon it will sit in under there and partly under the chassis and lift one whole side up. I tested and can lift the whole side up on the slider with the High Lift (did it with a mates when we were out a few weeks back just to test). I reckon it will work well. Was thinking to have a bit of old mudflap if there is anything not too flat, but not sure I'll need it.
    High lift has it's uses, but they can so easily catch you by surprise and as you say, are heavy (and bulky).
    There was a thread last year and several people piped up about how good they were and kept it in the back of my mind/wishlist. I just noticed the cheap price delivered on Kogan, so thought I'd give it a go. Will hopefully post up tomorrow what I think of this actual one.
    Thanks, Cameron
    No Patrol now - Just good memories!
  10. The Following User Says Thank You to cgm For This Useful Post:
    macca (28th February 2015)
  11. #968
    Jul 2012
    Ballarat
    Beast!.......
    Yeah does look pretty beastly! I've often wondered, when you buy something like this how do you get it roadworthy for transfer? I assume you have to put in some effort to temporarily put some stock suspension in, etc. until swapped across, then swap back and take the risk of getting pinged? Am I missing something obvious?
    Thanks, Cameron
  12. #969
    Feb 2015
    A can of expanda foam and some sikaflex to seal up the front firewall bungs, damn NT wet season
    Pick up virtue from everyone
  13. #970
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    A Navman MiVue 530 1080p dash cam with gps tracking.
    Ive tried a few of the cheaper versions but they just don't have the clarity even though they're supposed to be at least 720p.
  14. The Following User Says Thank You to mjr350 For This Useful Post:
    DX grunt (1st March 2015)
