Page 9 of 30 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 294
Thread: 04 gu bus...
  1. #81
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Cheers 3dogs...
  2. #82
    Feb 2015
    Finshed installing sound system yesturday... sounds so much better with amp subs and 6x9s in the back... also installed a 10 fuse panel up frnt under dash.. 5 constant. 5 keyd powr... makes it so much easier to wire up rocker switches/relays and power acc than running wires through firewall to battery...hopefully get some power through to these gauges if i get some time today...
  3. The Following User Says Thank You to mullet_hunter For This Useful Post:
    threedogs (28th February 2015)
  4. #83
    Feb 2015
    Still has the hrd startn issue and high idle... do these have like a crank sensor?
  5. #84
    Feb 2015
    Gauges are in... Just need to tap into boost n drill hole for pyro...
  6. #85
    yes and its a biatch to get to its called a crank angle sensor.
    They changed mine as the patrol was going into limp mode all the time
    Love your work
    Nice place right of that top gauge for a toggle switch for something
    Dont you need to weld a bung for the pyro????
    mullet_hunter (28th February 2015)
  8. #86
    Looking good mate.
    Keep it rolling.
    Sorry if you've written it but have you changed glow plugs yet?
    Feb 2015
    In the kit it comes with either a clamp fitting where you just drill hole and tightn clamp to dump pipe.. when funds permit il upgrade to 3 inch exhaust and get them to weld in the bung.. has adapter fitting so u can run either.. just not keen on taking off dump pipe to weld in bung.. too fiddly in this hot weather.. haha id rather just drill a hole.. n maybe tap it.. should work alright for nw...
  10. #88
    Feb 2015
    Love your work
    Ye my mate reckn it might be the crank angle sensor.. its got to be sum little scummy sensor messn things up with the high idle and hrd starting... slowing getn there...
  11. #89
    they ended up pulling half the front of my motor off to get to it.
    took most of the day, but fixed the limp mode problem
  12. #90
    Feb 2015
    We'll I took the bus out for bit of a thrash dwn the beach out 2 rocks ways.. I reckon once I sort the hrd startn and high idle I might have a half decent 4 wheel drive... Was cutting lose in only 2 wheel drive.. I can't fault it compared to my 80 except for one thing.. It has a crap turning circle... Which makes it so much harder to turn around in small spaces... So I'd dear say I'd scored me some custom bush pin stripping frm today's efferts... Hope everyone out enjoyn there long weeknd...
  13. The Following User Says Thank You to mullet_hunter For This Useful Post:
    BigRAWesty (28th February 2015)
