Results 1 to 5 of 5
Thread: dual battery isolator kit
    Expert Oldmate1's Avatar
    Mar 2013
    Brisbane. Wynnum West
    just seeing if anyone has used this dual battery kit i can get the cheap and dont know if i should just save up some more coin
    http://www.jaycar.com.au/productView.asp?ID=MB3686
    thanks
    Ron
    20013 ST Diesel manual, ARB delux bar with smittybuilt winch, Chinese roof rack, ipf spotties, tjm awing
    waeco cfx 50 and slide
    I have not heard of any issues with them.
    They are clones of the other 140 Amp systems that are around.
    Personally I prefer dual sensing Isolators such as the Redarc SBI12D but as a 'standard' Isolator they should be OK
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    Oldmate1 (25th February 2015)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I agree with ET above as most 4wd are running Redarc or similar. I have heard a couple of good reports from boat owner friends though.
  5. The Following User Says Thank You to 4bye4 For This Useful Post:
    I would only use the over ride function on that for emergency power. Not back up cranking or winching.
    170A is to low.
    The redarc simple isolator only a few $$$ more will handle a burst of 400A. So cranking of second battery is an option then.
    But that supplied cable won't handle crank current so is sized accordingly to the max amp of the unit.
  7. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    4bye4 (25th February 2015), Oldmate1 (25th February 2015)
  8. #5
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    I run the redarc sbi12, got the full red arc kit, delivered from Ebay for about $220 from memory, was a little while ago.
    It's done brilliantly for me so far.
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
